* score/inline/rtems/score/object.inl, score/src/objectnametoid.c:
Properly honor searching only local node even when on single CPU
system.
* score/src/coresemseize.c: Add missing ISR enable.
* score/src/heapwalk.c: Use printk not printf.
* rtems/score/types.h: Remove unsigned64, signed64.
* score/inline/rtems/score/threadq.inl, score/src/corerwlocktimeout.c:
New files.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
* cpu_asm.S: Properly support synchronous traps.
* score/Doxyfile: Remove RTEMS_INLINES.
* rtems/bfin/bf533.h, rtems/bfin/bfin.h: Remove stray whitespaces.
* rtems/score/bfin.h: Use __BFIN__ instead of BFIN.
* cpu_asm.S: Re-add HI, LO.
* irq.c: Add missing newline.
* rtems/score/cpu.h: Eliminate hidden backspaces.
PR 841/rtems
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semwait.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make
sem_timedwait more conformant to Open Group specification.
* rtems/bfin/bfin.h: Eliminate hi, lo, HI, LO, and MK_BMSK.
* Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/score/bfin.h:
Clean up rtems/score/bfin.h removing parts that are not needed by
RTEMS CPUkit to bfin specific .h files.
* rtems/bfin/bf533.h, rtems/bfin/bfin.h: New files.
* configure.ac, score/cpu/Makefile.am: Add bfin.
* cpu.c, rtems/score/cpu.h: Use the default IDLE thread body.
* .cvsignore, ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c,
preinstall.am, rtems/asm.h, rtems/score/bfin.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New files.
* score/Makefile.am, score/preinstall.am: Add pieces missed in previous
commit.
* configure.ac, itron/Makefile.am, itron/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
score/include/rtems/score/states.h,
score/inline/rtems/score/coresem.inl: Add SuperCore Barriers,
SpinLocks and a partial implementation of RWLocks.
* score/include/rtems/score/corebarrier.h,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl,
score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c,
score/src/corebarrierrelease.c, score/src/corebarrierwait.c,
score/src/corespinlock.c, score/src/corespinlockrelease.c,
score/src/corespinlockwait.c: New files.
* cpu.c: Remove warning.
* rtems/score/cpu.h: Revert change. It did not appear to correct all
warnings.
* score/include/rtems/score/object.h: _Objects_Local_node is a uint16_t
so cast the _Objects_Local_node constant to 1.
* rtems/score/cpu.h: Correct inline assembly constraints.
* cpu.c, rtems/score/sh.h: Recognize sh2e variant so multilibs will all
compile.
* .cvsignore: New file.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
Checked inline assembly; added early-clobber '&' to output operands
of multi-instruction asms.
PR 1124/rtems
* score/include/rtems/score/threadq.h, score/src/coremutexseize.c,
score/src/coremutexsurrender.c, score/src/threadqenqueue.c,
score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c:
The placement of the changing a thread's priority when using priority
ceiling should be on the successful transfer of the mutex -- not when
the thread tries to acquire. Plus the lack of a dispatch disable
point lead to the potential for a thread timing out and already
having inherited the ceiling priority.
PR 1101/rtems
* libcsupport/src/base_fs.c, rtems/src/taskcreate.c, rtems/src/tasks.c,
score/src/coremutex.c: Remove dead code.
* cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector
bits are used when calculating the exception vector.
* cpu.c: Added __mips==32 to fix build problems on those targets
caused by the Bruce Robinson.
B.Robinson patch
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, posix/src/ptimer.c,
posix/src/ptimer1.c, sapi/src/posixapi.c,
* itron/src/trcv_mbf.c, posix/src/semopen.c,
rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix
warnings.
* cpu.c, cpu_asm.S: Fixed ARM Data Abort handling.
score/macros/rtems/score/threadmp.inl: Fix compile error.
