The Classic binary semaphores without a locking protocol
(RTEMS_BINARY_SEMAPHORE) could be released by everyone, e.g. in contrast
to the POSIX mutexes (all variants) or the Classic binary semphores with
priority inheritance or ceiling, there was no owner check in the release
path.
This behaviour was a bit unexpected and not documented. Add an owner
check to the release path. Update sptests/sp42 accordingly.
This change has nothing to do with the simple binary semaphores
(RTEMS_SIMPLE_BINARY_SEMAPHORE) which have no owner at all.
Update #2725
The approach with the generation number was broken. The load/store of
the current lock, the thread queue and the thread queue operations were not
properly synchronized. Under certain conditions on a PowerPC T4240 old
thread queue operations operated on a new thread queue (NULL pointer).
A read-modify-write operation is necessary to read the last value
written.
See for example C11 standard or Power ISA 2.07, Book II: Power ISA
Virtual Environment Architecture, Section 1.6.3 Memory Coherence
Required [Category: Memory Coherence] and Section 1.7.3 Atomic Update.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Rework seize and surrender methods to use CORE_ceiling_mutex_Control.
This eliminates CORE_mutex_Disciplines.
Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid
the run-time evaluation of attributes to figure out how a particular
mutex methods should behave. Start with the no protocol variants. This
eliminates the CORE_MUTEX_DISCIPLINES_FIFO and
CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
Due to the unified status codes, we can now use a common flush and
destroy method for semaphore and mutex variants.
Remove superfluous support for simple binary semaphores. With this we
can get rid of the CORE_MUTEX_NESTING_BLOCKS variant.
Replace the ISR lock in MRSP_Control with a thread queue. This
simplifies the Classic semaphore implementation. Only the lock part of
the thread queue is used.
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Adjust thread queue layout according to Newlib. This makes it possible
to use the same implementation for <sys/lock.h> and CORE mutexes in the
future.
Close #2695.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Close #2720.
Close #2719.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
We must call the MP callout for proxies if we unblock them after a
thread queue extraction. This was missing in
_Thread_queue_Flush_critical(). Move thread remove timer and unblock
code to new function _Thread_Remove_timer_and_unblock().
of this patch set.
Close #2718.
Delete unused parameter.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Rename _Objects_Get_local() into _Objects_Get(). Confusions with the
previous _Objects_Get() function are avoided since the Objects_Locations
parameter is gone.
Delete now unused Objects_Locations.
Use _RBTree_Insert_inline() for priority thread queues.
Update #2556.
The priority values are only valid within a scheduler instance. Thus,
the maximum priority value must be defined per scheduler instance. The
first scheduler instance defines PRIORITY_MAXIMUM. This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance. Further
API/implementation changes are necessary to fix this.
Update #2556.
Update #2555.
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
Update #2555.
Avoid Giant lock for _Objects_Extend_information().
Update #2280.
Update #2555.
Update #2555.
Update #2555.
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Update #2555.
Rework pthread_join() to use _Thread_Join().
Close #2402.
Update #2555.
Update #2626.
Close #2714.
Use _Thread_Change_life_locked() to avoid duplicated code. Avoid Giant
lock in _Thread_Life_action_handler().
Update #2555.
Update #2626.
Rework _Thread_Cancel() to use _Thread_Change_life_locked().
Update #2555.
Update #2626.
Rework _Thread_Restart_other() to use _Thread_Change_life_locked().
Cope with concurrent change requests by means of a pending request
counter.
Update #2555.
Update #2626.
