* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
* configure.ac: Fix package name.
* macros/rtems/score/object.inl: Keep consistent with inline version.
* configure.ac: Generate unixsize.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* rtems/score/.cvsignore: unixsize*
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* idtcpu.h: Removed warnings.
* cpu.c: Removed warnings.
* rtems/score/cpu.h: Removed warning.
* src/heapgetinfo.c: Fixed comment.
* src/mpci.c: Removed warning.
* rtems/new-exceptions/cpu.h: Removed warnings.
* src/threadhandler.c: Prototype _init() and _main() if they are needed
to avoid a warning.
* idtcpu.h: Removed warning by turning extra token at the end of
an endif into a comment.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* rtems/score/sh.h: Fix typo in comment (Starus->Status).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* rtems/score/cpu.h: Fix u16 and u32 swap routines.
* rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL
since it is not used.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* cpu_asm.S: More PR267 tinkering which eliminates some conditional
compilation.
* macros/rtems/score/coremsg.inl: Add <string.h> to remove warning.
* src/threadidlebody.c: Add return 0 to avoid warning.
* cpu_asm.S: Per PR267, the _ISR_Handler() function never was modifying
_ISR_Nest_level, and _Watchdog_Insert() requires this variable
to be modified to determine if an interrupt may have modified
the watchdog chain. Prior to modifying _ISR_Handler(), I had
a test that would fail if _ISR_Flash was not commented out in
_Watchdog_Insert(). After this modification was made, my test
ran flawlessly.
* cpu_asm.S: Clarified some comments, removed code that forced
SR_IEP on when returning from an interrupt.
* cpu.c: Move pointer into #ifdef to avoid compiler warning.
* src/coretodset.c: Correct calculation of ticks until next section
boundary. It was incorrectly based upon current time not the
time that is being set.
* asm.h, rtems/score/cpu.h: Correct items that have changed since
RTEMS version or32 port was based upon.
* rtems/score/cpu.h, rtems/score/types.h: Updated to fix some typos.
* asm.h, cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/or32.h,
rtems/score/types.h: Merged from OpenCores CVS repository.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* memcpy.c: Moved to libcpu.
* Makefile.am: Modified to reflect above.
* src/Makefile.am: Build into libscore.a.
* .cvsignore, ChangeLog, asm.h, configure.ac, cpu.c, cpu_asm.c,
rtems/score/.cvsignore, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or16.h, rtems/score/types.h: Removed as the or16 port
was just a stub and only the OR32 port is getting worked on.
* cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: ARM port works
well enough to run all sptests, tmtests, and ttcp.
In addition to general cleanup, there has been considerable
optimization to interrupt disable/enable, endian swapping,
and context switching.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* include/rtems/score/apimutex.h (_API_Mutex_Lock): Per PR253
add the missing _ISR_Disable. This fix was already applied to
the old location (c/src/exec/score/...).
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
* cpu_asm.S: Added SR_IEO to context restore to fix isr disabled
deadlock caused by interrupt arriving while dispatching.
* macros/rtems/score/object.inl: Corrected typos in
_Objects_Open, _Objects_Close, and _Objects_Namespace_remove.
* macros/rtems/score/object.inl: Corrected implementation of
to be consistent with the inline implementation.
* cpu.c, irq.c, rtems/score/cpu.h: Filled in something that was
marked XXX.
* rtems/score/cpu.h: Filled in something that was marked XXX.
* Makefile.am: Remove reference to deprecated rtems.c.
* rtems.c: Remove.
* rtems.c: Remove.
