Change message type to unsigned long to match other SMP message functions.
Simplify _RBTree_Insert() and _RBTree_Extract(). Remove more
superfluous NULL pointer checks. Change _RBTree_Is_root() to use only
the node. Add parent parameter to _RBTree_Sibling(). Delete
_RBTree_Grandparent() and _RBTree_Parent_sibling().
The test sptests/sp35 showed a NULL pointer access due to an invalid
maximum node field (e.g. a tree with one element and NULL as the maximum
node).
This lays the proper structure for doing future work on
time adjustment algorithms. Any TOD adjustments should be
requested at the API level and performed at the SCORE level.
Additionally updated a test.
When a thread is removed from a thread queue or is unblocked
by receiving an event, the same actions are required.
+ timeout watchdog canceled,
+ thread must be unblocked, and
+ (MP only) proxy cleaned up
This patch makes sure there is only one copy of this code.
There was a lot of duplication between the discipline subroutines.
With the transition to RBTrees for priority discipline, there were
only a few lines of source code manipulating the data structure
for FIFO and priority. Thus is made sense to fold these back
into the main methods.
As part of doing this all of the tests for discipline were changed
to be in the same order.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
The priority affinity scheduler has the nice property that it can
produce more than one scheduled to ready state change in one operation.
Each scheduled to ready state change may lead to one thread in need for
help. Since it is currently only possible to return at most one thread
in need for help, we have a problem here.
A solution might be to move the check for migrations into the ask for
help mechanism.
Do not extract the idle threads from the ready set so that there is
always a thread available for comparison.
The following scheduler operations return a thread in need for help
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
Add a new ask for help scheduler operation. This operation is used by
_Scheduler_Ask_for_help() to help threads in need for help returned by
the operations mentioned above. This operation is also used by
_Scheduler_Thread_change_resource_root() in case the root of a resource
sub-tree changes. A use case is the ownership change of a resource.
In case it is not possible to schedule a thread in need for help, then
the corresponding scheduler node will be placed into the set of ready
scheduler nodes of the scheduler instance. Once a state change from
ready to scheduled happens for this scheduler node it may be used to
schedule the thread in need for help.
Return a thread in need for help for the following scheduler operations
- unblock,
- yield.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
Avoid copy and paste and set the scheduler node state in one place.
Rename and move _Scheduler_SMP_Update_heir() to
_Thread_Dispatch_update_heir() since this function is not scheduler
specific.
Add PER_CPU_OFFSET_HEIR. Move Per_CPU_Control::executing and
Per_CPU_Control::heir for easy offset calculation.
The _CPU_Context_Restart_self() implementations usually assume that self
context is executing.
FIXME: We have a race condition in _Thread_Start_multitasking() in case
another thread already performed scheduler operations and moved the heir
thread to another processor. The time frame for this is likely too
small to be practically relevant.
Close the thread object in _Thread_Make_zombie() so that all blocking
operations that use _Thread_Get() in the corresponding release directive
can find a terminating thread and can complete the operation.
Add a chain node to the scheduler node to decouple the thread and
scheduler nodes. It is now possible to enqueue a thread in a thread
wait queue and use its scheduler node at the same for other threads,
e.g. a resouce owner.
This reduces the API to the minimum data structures to maximize the
re-usability.
Add Thread_Scheduler_control to collect scheduler related fields of the
TCB.
Remove the scheduler parameter from most high level scheduler operations
like
- _Scheduler_Block(),
- _Scheduler_Unblock(),
- _Scheduler_Change_priority(),
- _Scheduler_Update_priority(),
- _Scheduler_Release_job(), and
- _Scheduler_Yield().
This simplifies the scheduler operations usage.
Suppose we have two tasks A and B and two processors. Task A is about
to delete task B. Now task B calls rtems_task_wake_after(1) on the
other processor. Task B will block on the Giant lock. Task A
progresses with the task B deletion until it has to wait for
termination. Now task B obtains the Giant lock, sets its state to
STATES_DELAYING, initializes its watchdog timer and waits. Eventually
_Thread_Delay_ended() is called, but now _Thread_Get() returned NULL
since the thread is already marked as deleted. Thus task B remained
forever in the STATES_DELAYING state.
Instead of passing the thread identifier use the thread control block
directly via the watchdog user argument. This makes
_Thread_Delay_ended() also a bit more efficient.
The _Scheduler_Yield() was called by the executing thread with thread
dispatching disabled and interrupts enabled. The rtems_task_suspend()
is explicitly allowed in ISRs:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR
Unlike the other scheduler operations the locking was performed inside
the operation. This lead to the following race condition. Suppose a
ISR suspends the executing thread right before the yield scheduler
operation. Now the executing thread is not longer in the set of ready
threads. The typical scheduler operations did not check the thread
state and will now extract the thread again and enqueue it. This
corrupted data structures.
Add _Thread_Yield() and do the scheduler yield operation with interrupts
disabled. This has a negligible effect on the interrupt latency.
These functions are used only via the function pointers in the generic
SMP scheduler implementation. Provide them as static inline so that the
compiler can optimize more easily.
This helps to avoid untestable code for the normal SMP schedulers.
This scheduler attempts to account for needed thread migrations caused
as a side-effect of a thread state, affinity, or priority change operation.
This scheduler has its own allocate_processor handler named
_Scheduler_SMP_Allocate_processor_exact() because
_Scheduler_SMP_Allocate_processor() attempts to prevent an executing
thread from moving off its current CPU without considering affinity.
Without this, the scheduler makes all the right decisions and then
they are discarded at the end.
==Side Effects of Adding This Scheduler==
Added Thread_Control * parameter to Scheduler_SMP_Get_highest_ready type
so methods looking for the highest ready thread can filter by the processor
on which the thread blocking resides. This allows affinity to be considered.
Simple Priority SMP and Priority SMP ignore this parameter.
+ Added get_lowest_scheduled argument to _Scheduler_SMP_Enqueue_ordered().
+ Added allocate_processor argument to the following methods:
- _Scheduler_SMP_Block()
- _Scheduler_SMP_Enqueue_scheduled_ordered()
+ schedulerprioritysmpimpl.h is a new file with prototypes for methods
which were formerly static in schedulerprioritysmp.c but now need to
be public to be shared with this scheduler.
NOTE:
_Scheduler_SMP_Get_lowest_ready() appears to have a path which would
allow it to return a NULL. Previously, _Scheduler_SMP_Enqueue_ordered()
would have asserted on it. If it cannot return a NULL,
_Scheduler_SMP_Get_lowest_ready() should have an assertions.
Replace _Per_CPU_State_wait_for_ready_to_start_multitasking() with
_Per_CPU_State_wait_for_non_initial_state(). Implement this function.
Rename _Scheduler_Update() to _Scheduler_Update_priority(). Add
parameter for the new thread priority to avoid direct usage of
Thread_Control::current_priority in the scheduler operation.
Replace _Scheduler_Allocate() with _Scheduler_Node_initialize(). Remove
the return status and thus the node initialization must be always
successful.
Rename _Scheduler_Free() to _Scheduler_Node_destroy().
A resource is something that has at most one owner at a time and may
have multiple rivals in case an owner is present. The owner and rivals
are impersonated via resource nodes. A resource is represented via the
resource control structure. The resource controls and nodes are
organized as trees. It is possible to detect deadlocks via such a
resource tree. The _Resource_Iterate() function can be used to iterate
through such a resource tree starting at a top node.
Do not change the scheduler with this function. Documentation. Coding
style.
Drop scheduler parameter. Coding style.
Do not use the Per_CPU_Control::started in
_SMP_Start_multitasking_on_secondary_processor() since this field may be
not up to date when a secondary processor reads it. Use the read-only
scheduler assignment instead.
Add a new fatal error SMP_FATAL_MULTITASKING_START_ON_INVALID_PROCESSOR.
This prevents out-of-bounds access.
It is currently not possible to test these fatal errors. One option
would be to fake values of the _CPU_SMP_Get_current_processor(), but
unfortunately this function is inline on some architectures.
