Remove previous adjtime() implementation.
Update #2348.
The file was imported from this repository:
https://github.com/freebsd/freebsd.git
This commit was used:
commit 3ec0dc367bff27c345ad83240625b2057af391b9
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Mon Feb 7 14:16:16 2022 -0700
kern_ntptime.c: Remove ntp_init()
The ntp_init() function did set a couple of global objects to zero. These
objects are in the .bss section and already initialized to zero during kernel
or module loading.
Update #2348.
There are two places where we convert from a timecounter delta to
a bintime delta: tc_windup and bintime_off.
Both functions use the same calculations when the timecounter delta is
small. But for a large delta (greater than approximately an equivalent
of 1 second) the calculations were different. Both functions use
approximate calculations based on th_scale that avoid division. Both
produce values slightly greater than a true value, calculated with
division by tc_frequency, would be. tc_windup is slightly more
accurate, so its result is closer to the true value and, thus, smaller
than bintime_off result.
As a consequence there can be a jump back in time when time hands are
switched after a long period of time (a large delta). Just before the
switch the time would be calculated with a large delta from
th_offset_count in bintime_off. tc_windup does the switch using its own
calculations of a new th_offset using the large delta. As explained
earlier, the new th_offset may end up being less than the previously
produced binuptime. So, for a period of time new binuptime values may
be "back in time" comparing to values just before the switch.
Such a jump must never happen. All the code assumes that the uptime is
monotonically nondecreasing and some code works incorrectly when that
assumption is broken. For example, we have observed sleepq_timeout()
ignoring a timeout when the sbinuptime value obtained by the callout
code was greater than the expiration value, but the sbinuptime obtained
in sleepq_timeout() was less than it. In that case the target thread
would never get woken up.
The unified calculations should ensure the monotonic property of the
uptime.
The problem is quite rare as normally tc_windup should be called HZ
times per second (typically 1000 or 100). But it may happen in VMs on
very busy hypervisors where a VM's virtual CPU may not get an execution
time slot for a second or more.
Reviewed by: kib
MFC after: 2 weeks
Sponsored by: Panzura LLC
Hyper-V wants to register its MSR-based timecounter during
SI_SUB_HYPERVISOR, before SI_SUB_LOCK, since an emulated 8254 may not be
available for DELAY(). So we cannot use MTX_SYSINIT to initialize the
timecounter lock.
PR: 259878
Reviewed by: kib
MFC after: 3 days
Sponsored by: The FreeBSD Foundation
Differential Revision: https://reviews.freebsd.org/D33014
The BSPs provide memory for the workspace initialization via
_Memory_Get(). Most BSPs provide exactly one memory area. Only two
BSPs provide more than one memory area (arm/altera-cyclone-v and
bsps/powerpc/mpc55xxevb). Only if more than one memory area is
provided, there is a need to use _Heap_Extend(). Provide two
implementations to initialize the workspace handler and let the BSP
select one of the implementations based on the number of provided memory
areas. This gets rid of a dependency on _Heap_Extend(). It also avoids
dead code sections for most BSPs.
Splitting the file avoids unnecessary link-time dependencies.
Change licence according to file history.
Update #3053.
The _Thread_queue_Extract() does not deal with potential priority
updates and the SMP locking protocol handling. Use
_Thread_queue_Continue(). For the POSIX signals processing this is
currently probably unnecessary, however, the use case is similar to the
restart so use the same appoach.
Close #4546.
Simplify _Thread_queue_Surrender_no_priority() and use
_Thread_queue_Resume().
Update #4546.
Move _Thread_queue_Extract() since this function is not used by the core
services (threads, semaphores, mutexes, message queues).
Update #4546.
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something. Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY. This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
Remove _Thread_queue_Extract_with_proxy() and move the proxy extraction
to _Thread_MP_Extract_proxy(). Move similar code blocks of the previous
caller of _Thread_queue_Extract_with_proxy() to helper functions.
Update #4546.
The earlier we remove the thread timer the less likely is a superfluous
thread timeout processing.
Update #4546.
The SMP EDF scheduler supports a one-to-one and one-to-all thread to
processor affinity. It accepted affinity sets which are a proper
subset of the online processor containing at least two processors owned by
the scheduler. In this case it used a one-to-one thread to processor
affinity. This leads to undefined behaviour if a processor is removed
since the higher level check in rtems_scheduler_remove_processor() does
not account for this implementation detail.
Restrict the affinity set accepted by the SMP EDF scheduler to
1. all online processors, or
2. exactly one processor owned by the scheduler.
Close #4545.
Process ask for help requests on the current processor. This avoids
using inter-processor interrupts to make the system behaviour a bit more
predictable.
Update #4531.
Simplify callers of _Scheduler_SMP_Schedule_highest_ready(). Move the node
state change and the extraction from scheduled into
_Scheduler_SMP_Schedule_highest_ready(). Move the idle thread release to the
caller which have more information about the presence of an idle thread.
Update #4531.
Update #4531.
The SMP EDF scheduler supports one-to-one and one-to-all thread to
processor affinities. The one-to-one thread to processor affinity
introduces a constraint on the ordering of threads. The implementation
uses one ready queue for threads which have a one-to-all affinity and
one for each one-to-one affinity group. To order threads across the
ready queues, a generation number is used. However, the approach to
update the generation number each time a thread is inserted into a ready
queue was wrong. The generation number needs to be updated only in the
enqueue and enqueue scheduled operations where an insert priority is
available. The scheduled chain needs to take the generation number into
account.
An example scenario which shows the bug is this. Let T be a high
priority task affine to processor X. Let A be a lower priority task
affine to processor X. Let B be a lower priority task with no affinity
to a particular processor which executes on processor Y. Let B be in
the same priority group than A and after A. Let T set the affinity to
all processors. Now A (higher priority relative to B) should execute on
X and T (high priority) should execute on Y.
Close #4534.
This allows to use additional members of the nodes for comparision.
Update #4534.
This patch fixes an issue with the idle thread handling in the SMP
scheduler framework used for the MrsP locking protocol. The approach to
use a simple chain of unused idle threads is broken for schedulers which
support thread to processor affinity. The reason is that the thread to
processor affinity introduces another ordering indicator which may under
certain conditions lead to a reordering of idle threads in the scheduled
chain. This reordering is not propagated to the chain of unused idle
threads. This could lead to use an idle thread for a sticky scheduler
node which is already in use. This locks up the system in infinite
loops in the thread context switch procedure.
To fix this, the SMP scheduler implementations must now provide
callbacks to get and release an unused idle thread.
Update #4531.
This patch fixes the following broken behaviour:
While a thread is scheduled on a helping scheduler, while it does not
own a MrsP semaphore, if it obtains a MrsP semaphore, then no
scheduler node using an idle thread and the ceiling priority of the
semaphore is unblocked for the home scheduler.
This could lead to priority inversion issues and is not in line
with the MrsP protocol.
Introduce two new scheduler operations which are only enabled if
RTEMS_SMP is defined. The operations are used to make the scheduler
node of the home scheduler sticky and to clean the sticky property.
This helps to keep the sticky handing out of the frequently used
priority update operation.
Close #4532.
If a node is moved from the scheduled chain to the ready queue, then we
know that it is the highest priority ready node. So, it can be
prepended to the ready queue without doing any comparisons.
Update #4531.
Rework the handling of the affine ready queue for the EDF SMP scheduler.
Do the queue handling in the node insert, move, and extract operations.
Remove the queue handling from _Scheduler_EDF_SMP_Allocate_processor().
Update #4531.
Use the extract from scheduled callback provided by the scheduler
implementation in the SMP scheduler framework.
Update #4531.
The return value was unused. Remove it.
Update #4531.
These functions are a faster alternative to _RBTree_Insert_inline() if
it is known that the new node is the maximum/minimum node.
Update #4531.
These two OAR copyright headers are the only two in the codebase with
a format that differs from the typical OAR copyright header. This makes
all of the OAR copyright headers consistent.
Update #4527.
Allow the installation of an NTP update second handler which may be used by an
NTP service.
Update #2348.
In uniprocessor configurations, the timehand updates are done with
interrupts disabled. So, it is impossible to observe a generation
number of zero.
This leads to a timehand generation overflow right at the system start
and helps to get code coverage in test programs.
Reported by: Sebastian Huber <sebastian.huber@embedded-brains.de>
Reviewed by: kib
MFC after: 1 week
Differential Revision: https://reviews.freebsd.org/D32729
This change is a slight performance optimization for systems with a slow
64-bit division.
The th->th_scale and th->th_large_delta values only depend on the
timecounter frequency and the th->th_adjustment. The timecounter
frequency of a timehand only changes when a new timecounter is activated
for the timehand. The th->th_adjustment is only changed by the NTP
second update. The NTP second update is not done for every call of
tc_windup().
Move the code block to recalculate the scaling factor and
the large delta of a timehand to the new helper function
recalculate_scaling_factor_and_large_delta().
Call recalculate_scaling_factor_and_large_delta() when a new timecounter
is activated and a NTP second update occurred.
MFC after: 1 week
Timecounter registration is dynamic, i.e., there is no requirement that
timecounters must be registered during single-threaded boot. Loadable
drivers may in principle register timecounters (which can be switched to
automatically). Timecounters cannot be unregistered, though this could
be implemented.
Registered timecounters belong to a global linked list. Add a mutex to
synchronize insertions and the traversals done by (mpsafe) sysctl
handlers. No functional change intended.
Reviewed by: imp, kib
MFC after: 2 weeks
Differential Revision: https://reviews.freebsd.org/D32511
MFC after: 1 week
FreeBSD Foundation sys/ copyrights
These ones were unambiguous cases where the Foundation was the only
listed copyright holder (in the associated license block).
In FreeBSD, the current time is computed from uptime + boottime. Uptime
is a continuous, smooth function that's monotonically increasing. To
effect changes to the current time, boottime is adjusted. boottime is
mutable and shouldn't be cached against future need. Document the
current implementation, with the caveat that we may stop stepping
boottime on resume in the future and will step uptime instead (noted in
the commit message, but not in the code).
Sponsored by: Netflix
Reviewed by: phk, rpokala
Differential Revision: https://reviews.freebsd.org/D30116
Noted and reviewed by: kevans
MFC after: 1 week
Differential revision: https://reviews.freebsd.org/D29122
MFC after: 1 week
on freebsd/arm64:
- Implement a dtrace_getnanouptime(), matching the existing
dtrace_getnanotime(), to avoid DTrace calling out to a potentially
instrumentable function.
(These should probably both be under KDTRACE_HOOKS. Also, it's not clear
to me that they are correct implementations for the DTrace thread time
functions they are used in .. fixes for another commit.)
- Don't allow FBT to instrument functions involved in EL1 exception handling
that are involved in FBT trap processing: handle_el1h_sync() and
do_el1h_sync().
- Don't allow FBT to instrument DDB and KDB functions, as that makes it
rather harder to debug FBT problems.
Prior to these changes, use of FBT on FreeBSD/arm64 rapidly led to kernel
panics due to recursion in DTrace.
Reliable FBT on FreeBSD/arm64 is reliant on another change from @andrew to
have the aarch64 instrumentor more carefully check that instructions it
replaces are against the stack pointer, which can otherwise lead to memory
corruption. That change remains under review.
MFC after: 2 weeks
Reviewed by: andrew, kp, markj (earlier version), jrtc27 (earlier version)
Differential revision: https://reviews.freebsd.org/D27766
to warm timecounters.
It seems that second call does not add any useful state change for all
implemented timecounters.
Discussed with: bde
MFC after: 3 weeks
or CTLFLAG_NEEDGIANT (17 of many)
r357614 added CTLFLAG_NEEDGIANT to make it easier to find nodes that are
still not MPSAFE (or already are but aren’t properly marked).
Use it in preparation for a general review of all nodes.
This is non-functional change that adds annotations to SYSCTL_NODE and
SYSCTL_PROC nodes using one of the soon-to-be-required flags.
Mark all obvious cases as MPSAFE. All entries that haven't been marked
as MPSAFE before are by default marked as NEEDGIANT
Approved by: kib (mentor, blanket)
Commented by: kib, gallatin, melifaro
Differential Revision: https://reviews.freebsd.org/D23718
and fix possible overflow in bintime()/binuptime().
The algorithm to read the consistent snapshot of current timehand is
repeated in each accessor, including the details proper rollup
detection and synchronization with the writer. In fact there are only
two different kind of readers: one for bintime()/binuptime() which has
to do the in-place calculation, and another kind which fetches some
member from struct timehand.
Extract the logic into type-checked macros, GETTHBINTIME() for bintime
calculation, and GETTHMEMBER() for safe read of a structure' member.
This way, the synchronization is only written in bintime_off() and
getthmember().
In bintime_off(), use overflow-safe calculation of th_scale *
delta(timecounter). In tc_windup, pre-calculate the min delta value
which overflows and require slow algorithm, into the new timehands
th_large_delta member.
This part with overflow fix was written by Bruce Evans.
Reported by: Mark Millard <marklmi@yahoo.com> (the overflow issue)
Tested by: pho
Discussed with: emaste
Sponsored by: The FreeBSD Foundation (kib)
MFC after: 3 weeks
No functional changes.
Reported and tested by: trasz
MFC after: 1 week
Tested by: O'Connor, Daniel <darius@dons.net.au>
MFC after: 1 week
Differential revision: https://reviews.freebsd.org/D21563
This patch was modified by Sebastian Huber
<sebastian.huber@embedded-brains.de> to adjust it for RTEMS. See
comment in the patch.
that uses 64bits time_t in 32bits mode, special case amd64, as i386 is
the only arch that still uses 32bits time_t.
On arm64 (and possible other architectures) we are unable to use static
DPCPU data in kernel modules. This is because the compiler will generate
PC-relative accesses, however the runtime-linker expects to be able to
relocate these.
In preparation to fix this create two macros depending on if the data is
global or static.
Reviewed by: bz, emaste, markj
Sponsored by: ABT Systems Ltd
Differential Revision: https://reviews.freebsd.org/D16140
