comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
The _API_extensions_Run_postswitch() function is only used in
_Thread_Dispatch(). Avoid superfluous load of _Thread_Executing.
The _User_extensions_Thread_switch() function is only used in
_Thread_Dispatch().
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
Call the fatal handlers of the user extensions before the update of
_Internal_errors_What_happened. This reduces the requirements on the
execution context further. Now a valid read-write data is only required
after the call to the fatal handlers.
This reverts commit 7d0bdcac1ac20d6f22b24689c16e6aa7bc3c1e40.
Delete _TOD_Get_as_timestamp().
Add Internal_errors_Information::nest_level. This helps to detect
recursive calls to _Internal_error_Occurred().
Define _System_state_Current and _Internal_errors_What_happened in
interr.c to make _Internal_error_Occurred() more independent.
The initial extensions remain now in a read-only table and will not be
copied to work space memory. The extension chains are statically
initialized. This makes it possible to call _User_extensions_Iterate()
independent of the system state. It is now guaranteed that the fatal
callout of the initial extensions will be called provided the stack
pointer, the read-only data, and code memory are valid.
Replace the separate user extension iterations with a single iteration
function. This reduces code size and improves maintainability since the
iteration logic is only in one function. The runtime overhead is
insignificant.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
The _Heap_Extend() has now the same signature as _Heap_Initialize().
The 4th parameter is ignored (page size in _Heap_Initialize()).
Add Heap_Area and Heap_Initialization_or_extend_handler.
Add and test _Heap_No_extend().
This helps to do a table based heap initialization and extension.
Create a table of Heap_Area elements and iterate through it. Set the
handler to _Heap_Initialize() in the first iteration and then to
_Heap_Extend().
Use _Workspace_Allocate_or_fatal_error() consistently in case auto
extend is turned off. This helps to avoid undefined behaviour in
_API_Mutex_Allocate() in case _API_Mutex_Information() fails.
The changes in _Thread_Dispatch() of commits
dad36c52b8be5d7b46bc7af85655055db7208652 and
d4dc7c8196355f08044e67a3f5c1e19485f17ff1 introduced a severe bug which
destroys the real-time properties of RTEMS completely.
Consider the following scenario. We have three tasks L (lowest
priority), M (middle priority), and H (highest priority). Now let a
thread dispatch from M to L happen. An interrupt occurs in
_Thread_Dispatch() here:
void _Thread_Dispatch( void )
post_switch:
_ISR_Enable( level );
<-- INTERRUPT
<-- AFTER INTERRUPT
_Thread_Unnest_dispatch();
_API_extensions_Run_postswitch();
The interrupt event makes task H ready. The interrupt code will see
_Thread_Dispatch_disable_level > 0 and thus doesn't perform a
_Thread_Dispatch(). Now we return to position "AFTER INTERRUPT". This
means task L executes now although task H is ready! Task H will execute
once someone calls _Thread_Dispatch().
This code was reviewed as part of coverage analysis improvements. The
uncovered range had unclear documentation and the code itself was also
cleaned up to be easier to understand.
Author: Krzysztof Mięsowicz <krzysztof.miesowicz@gmail.com>
The 64-bit timestamps were introduced to simplify the timestamp
calculations. This works well since nearly all operations are
additions. The previous _TOD_Tickle_ticks() implementation had a
serious performance regression in case of 64-bit timestamps due to the
usage of two 64-bit divisions which are quite expensive on some
architectures.
A new field seconds_trigger in TOD_Control is introduced to trigger the
_Watchdog_Tickle_seconds() in _TOD_Tickle_ticks(). This avoids the
64-bit divisions completely and only 32-bit additions are used.
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set)
in a structure to reduce address loads in _TOD_Tickle_ticks().
Save the return value from the unprotected version and return it after
enabling interrupts to their previous level.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
The implementation of RBTree_Next was using an awkward construction to detect
and avoid accessing the false root of the red-black tree. To deal with the
false root, RBTree_Next was comparing node parents with the control node.
Instead the false root can be detected by checking if the grandparent of a
node exists; the grandparent of the tree's true root is NULL by definition
so the root of the tree is found while walking up the tree by checking for
the non-existence of a grandparent.
This change propagates into the predecessor/successor and iterate functions.
When inserting to a red-black tree with duplicates the min and max pointers are
not updated properly. We need to check the key of the min/max node against the
insert node since the insert point could be the child of a node with an
identical key to the min/max node.
During node extraction from a red-black tree the min and max values are updated
incorrectly. We need to use the successor/predecessor functions to find the
next/previous node when we remove the min/max from the tree.
Make default for rtems_rbtree functions be unprotected (preemption enabled)
unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is available.
