path: root/cpukit/score/src/threadqfirst.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Simplify thread queue acquire/releaseSebastian Huber2016-09-081-4/+4
* score: Remove Thread_queue_Queue::operations fieldSebastian Huber2016-03-291-2/+3
| | | | | | | | | Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects.
* score: New thread queue implementationSebastian Huber2015-05-191-7/+0
| | | | | | | | | Use thread wait flags for synchronization. The enqueue operation is now part of the initial critical section. This is the key change and enables fine grained locking on SMP for objects using a thread queue like semaphores and message queues. Update #2273.
* score: More thread queue operationsSebastian Huber2015-05-191-18/+1
| | | | | | | | | Move thread queue discipline specific operations into Thread_queue_Operations. Use a separate node in the thread control block for the thread queue to make it independent of the scheduler data structures. Update #2273.
* score: Add Thread_queue_Control::LockSebastian Huber2015-05-191-7/+15
| | | | | | | | | | | Move the complete thread queue enqueue procedure into _Thread_queue_Enqueue_critical(). It is possible to use the thread queue lock to protect state of the object embedding the thread queue. This enables per object fine grained locking in the future. Delete _Thread_queue_Enter_critical_section(). Update #2273.
* Add and use RTEMS_CONTAINER_OF()Sebastian Huber2014-08-051-2/+3
* Thread Queue: Merge discipline subroutines into main methodsJoel Sherrill2014-07-151-7/+22
| | | | | | | | | | | There was a lot of duplication between the discipline subroutines. With the transition to RBTrees for priority discipline, there were only a few lines of source code manipulating the data structure for FIFO and priority. Thus is made sense to fold these back into the main methods. As part of doing this all of the tests for discipline were changed to be in the same order.
* score: Create threadq implementation headerSebastian Huber2013-07-261-7/+1
| | | | | | | | Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h.
* score: Create states implementation headerSebastian Huber2013-07-261-1/+0
| | | | | | Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API.
* score misc: Score misc: Clean up Doxygen #7 (GCI 2012)Alex Ivanov2012-11-291-16/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2008-01-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-221-13/+6
| | | | * score/src/threadqfirst.c: Remove switch.
* 2008-01-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-221-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems/include/rtems/rtems/event.h, rtems/inline/rtems/rtems/eventset.inl, rtems/src/event.c, rtems/src/eventseize.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/interr.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tqdata.h, score/inline/rtems/score/threadq.inl, score/inline/rtems/score/tqdata.inl, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadqtimeout.c: Refactor thread queue enqueue and event blocking synchronization critical sections. This resulted in three copies of essentially the same hard to test critical section code becoming the one shared routine _Thread_blocking_operation_Cancel. In addition, the thread queue and event code now share a common synchronization enumerated type. Along the way, switches were reworked to eliminate dead code generated by gcc and comments and copyrights were updated. * score/include/rtems/score/threadsync.h, score/src/threadblockingoperationcancel.c: New files.
* Include config.h.Ralf Corsepius2005-01-271-0/+4
* Remove stray white spaces.Ralf Corsepius2004-04-151-1/+0
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* Split threadq.c into multiple files.Joel Sherrill1999-11-021-0/+59
