The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
On ARM Thumb we may have function addresses ending with 0x7f, if we are
lucky.
Initialize the thread queue context with invalid data in debug
configurations to catch missing set up steps.
Move thread state for _Thread_queue_Enqueue() to the thread queue
context. This reduces the parameter count of _Thread_queue_Enqueue()
from five to four (ARM for example has only four function parameter
registers). Since the thread state is used after several function calls
inside _Thread_queue_Enqueue() this parameter was saved on the stack
previously.
Delete unused _Thread_queue_Enqueue() and rename
_Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue().
Replace the expected thread dispatch disable level with a thread queue
enqueue callout. This enables the use of _Thread_Dispatch_direct() in
the thread queue enqueue procedure. This avoids impossible exection
paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
This makes it easier to conditionally enable/disable the thread resource
count usage.
Update #2556.
Maintain the priority of a thread for each scheduler instance via the
thread queue enqueue, extract, priority actions and surrender
operations. This replaces the primitive priority boosting.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
This is an optimization for _Thread_queue_Surrender(). It helps to
encapsulate the priority boosting in the priority inheritance thread
queue operations.
Dismantle _Thread_queue_Do_extract_locked() into re-usable parts like
_Thread_queue_MP_set_callout() and _Thread_queue_Make_ready_again().
Use them in _Thread_queue_Surrender() to propare for a new thread queue
surrender operation.
Add _Thread_queue_Surrender() to unify the mutex surrender procedures
which involve a thread queue operation.
This helps to detect double insert and extract errors.
It is possible that the owner of the terminal link of a thread queue
path waits on a thread queue. However, this thread queue has no owner,
e.g. a thread queue of a message queue.
Update #2556.
There was a subtile race condition in _Thread_queue_Do_extract_locked().
It must first update the thread wait flags and then restore the default
thread wait state. In the previous implementation this could lead under
rare timing conditions to an ineffective _Thread_Wait_tranquilize()
resulting to a corrupt system state.
Update #2556.
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Move the priority change due to priority interitance to the thread queue
enqueue operation to simplify the locking on SMP configurations.
Update #2412.
Update #2556.
Update #2765.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
The use of atomic fences is brittle and may break due to changes in
different areas which is hard to manage.
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
We must call the MP callout for proxies if we unblock them after a
thread queue extraction. This was missing in
_Thread_queue_Flush_critical(). Move thread remove timer and unblock
code to new function _Thread_Remove_timer_and_unblock().
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
We must update the wait flags under protection of the current thread
lock, otherwise a _Thread_Timeout() running on another processor may
interfere.
We must provide thread queue heads for the thread wait information for
each thread proxy (thread queue heads were introduced by
d7665823b208daefb6855591d808e1f3075cedcb). The thread proxy must be
allocated before the enqueue operation.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
This enables external libraries to use thread locks since they are
independent of the actual RTEMS build configuration, e.g. profiling
enabled or disabled.
This makes it possible to use _Thread_queue_Extract_locked() for barrier
operations which extract all threads on the queue in one critical
section.
Separate the thread queue heads and lock from the operations. This
enables the support for light weight objects which only support one
queuing discipline.
Thread dispatching is disabled in case interrupts are disabled. To get
an accurate thread dispatch disabled time it is important to use the
interrupt disabled instant in case a transition from an interrupt
disabled section to a thread dispatch level section happens.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
Move thread queue discipline specific operations into
Thread_queue_Operations. Use a separate node in the thread control
block for the thread queue to make it independent of the scheduler data
structures.
Update #2273.
Replace the Thread_Priority_control with more general
Thread_queue_Operations which will be used for generic priority change,
timeout, signal and wait queue operations in the future.
Update #2273.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations. Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
