Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of stack.h and stack.inl into new
header file stackimpl.h. The stack.h contains now only the application
visible API.
Add and use _Scheduler_Start_idle().
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
The _Thread_Initialize() function has nothing to do with thread
dispatching it simply initializes the thread control.
This field is unused except for special case simulator clock drivers.
In these places use an alternative. Add and use
_Thread_Set_global_exit_status() and _Thread_Get_global_exit_status().
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* score/Makefile.am, score/preinstall.am,
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/threadcreateidle.c: Modifications to restrict compilation
of SMP only code to when SMP is enabled. Entire SMP specific files
are disabled via Makefile.am.
PR 1784
* sapi/src/exinit.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/bspsmp.h, score/src/percpu.c, score/src/smp.c,
score/src/threadcreateidle.c: Split bspsmp.h into two files smp.h and
bspsmp.h
* score/include/rtems/score/smp.h: New file.
PR 1729/cpukit
* configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c,
score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S,
score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/context.h,
score/src/thread.c, score/src/threadcreateidle.c: Add next step in
SMP support. This adds an allocated array of the Per_CPU structures
to support multiple cpus vs a single instance of the structure which
is still used if SMP support is disabled. Configuration support is
also added to explicitly enable or disable SMP. But SMP can only be
enabled for the CPUs which will support it initially -- SPARC and
i386. With the stub BSP support, a BSP can be run as a single core
SMP system from an RTEMS data structure standpoint.
* aclocal/check-smp.m4, aclocal/enable-smp.m4,
score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h,
score/src/smp.c, score/src/smplock.c: New files.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
* score/include/rtems/score/object.h,
score/inline/rtems/score/object.inl,
score/src/objectgetnameasstring.c, score/src/objectidtoname.c,
score/src/objectinitializeinformation.c,
score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c, score/src/thread.c,
score/src/threadcreateidle.c: Disable object string name support when
POSIX is not enabled.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* sapi/include/confdefs.h, score/src/threadcreateidle.c: Idle thread
body is now completely configured via the Configuration table.
* posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/pthreadcreate.c, rtems/include/rtems.h, rtems/src/attr.c,
score/inline/rtems/score/stack.inl, score/src/isr.c,
score/src/mpci.c, score/src/threadcreateidle.c,
score/src/threadinitialize.c, score/src/threadstackallocate.c: Add
ability for application to configure minimum stack size. Add
RTEMS_CONFIGURED_MINIMUM_STACK_SIZE constant so user can clearly
indicate they want the configured as opposed to the recommended
minimum stack size.
* itron/include/rtems/itron/task.h, itron/src/cre_tsk.c,
posix/src/pthreadcreate.c, rtems/src/taskcreate.c,
rtems/src/taskdelete.c, rtems/src/timerserver.c,
score/src/threadinitialize.c: Switch task create and delete
operations to using API Allocator Mutex. This moves almost all uses
of the RTEMS Workspace from dispatching disabled to mutex protected
which should improve deterministic behavior. The implementation was
carefully done to allow task create and delete extensions to invoke
more services. In particular, a task delete extension should be able
to do mutex and file operations.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
PR 484/rtems
* src/threadcreateidle.c: Idle task name was initialized incorrectly.
split into one function per file, this will decrease the size of executables.
