Update #3706
Add extract from scheduled function to the _Scheduler_SMP_Block()
operation. This allows a scheduler implementation to do extra work in
case a scheduled node is blocked.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
Change the chain order relation to use a directly specified left hand
side value. This is similar to _RBTree_Insert_inline() and helps the
compiler to better optimize the code.
Update #3059.
In SMP configurations, add a red-black tree node to Scheduler_Node to
enable an EDF scheduler implementation.
Update #3056.
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Update #2797.
Update #2556.
Remove unused return status.
Update #2556.
Changed for consistency with other scheduler operations.
Update #2556.
Update #2556.
Update #2556.
This enables to call this scheduler operation for all scheduler nodes
available to a thread.
Update #2556.
Rename the scheduler ask for help stuff since this will be replaced step
by step with a second generation of the scheduler helping protocol.
Keep the old one for now in parallel to reduce the patch set sizes.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Provide the scheduler node to initialize or destroy to the corresponding
operations. This makes it possible to have more than one scheduler node
per thread.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
Do not extract the idle threads from the ready set so that there is
always a thread available for comparison.
The following scheduler operations return a thread in need for help
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
Add a new ask for help scheduler operation. This operation is used by
_Scheduler_Ask_for_help() to help threads in need for help returned by
the operations mentioned above. This operation is also used by
_Scheduler_Thread_change_resource_root() in case the root of a resource
sub-tree changes. A use case is the ownership change of a resource.
In case it is not possible to schedule a thread in need for help, then
the corresponding scheduler node will be placed into the set of ready
scheduler nodes of the scheduler instance. Once a state change from
ready to scheduled happens for this scheduler node it may be used to
schedule the thread in need for help.
Return a thread in need for help for the following scheduler operations
- unblock,
- yield.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
Avoid copy and paste and set the scheduler node state in one place.
Add a chain node to the scheduler node to decouple the thread and
scheduler nodes. It is now possible to enqueue a thread in a thread
wait queue and use its scheduler node at the same for other threads,
e.g. a resouce owner.
The _Scheduler_Yield() was called by the executing thread with thread
dispatching disabled and interrupts enabled. The rtems_task_suspend()
is explicitly allowed in ISRs:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR
Unlike the other scheduler operations the locking was performed inside
the operation. This lead to the following race condition. Suppose a
ISR suspends the executing thread right before the yield scheduler
operation. Now the executing thread is not longer in the set of ready
threads. The typical scheduler operations did not check the thread
state and will now extract the thread again and enqueue it. This
corrupted data structures.
Add _Thread_Yield() and do the scheduler yield operation with interrupts
disabled. This has a negligible effect on the interrupt latency.
This scheduler attempts to account for needed thread migrations caused
as a side-effect of a thread state, affinity, or priority change operation.
This scheduler has its own allocate_processor handler named
_Scheduler_SMP_Allocate_processor_exact() because
_Scheduler_SMP_Allocate_processor() attempts to prevent an executing
thread from moving off its current CPU without considering affinity.
Without this, the scheduler makes all the right decisions and then
they are discarded at the end.
==Side Effects of Adding This Scheduler==
Added Thread_Control * parameter to Scheduler_SMP_Get_highest_ready type
so methods looking for the highest ready thread can filter by the processor
on which the thread blocking resides. This allows affinity to be considered.
Simple Priority SMP and Priority SMP ignore this parameter.
+ Added get_lowest_scheduled argument to _Scheduler_SMP_Enqueue_ordered().
+ Added allocate_processor argument to the following methods:
- _Scheduler_SMP_Block()
- _Scheduler_SMP_Enqueue_scheduled_ordered()
+ schedulerprioritysmpimpl.h is a new file with prototypes for methods
which were formerly static in schedulerprioritysmp.c but now need to
be public to be shared with this scheduler.
NOTE:
_Scheduler_SMP_Get_lowest_ready() appears to have a path which would
allow it to return a NULL. Previously, _Scheduler_SMP_Enqueue_ordered()
would have asserted on it. If it cannot return a NULL,
_Scheduler_SMP_Get_lowest_ready() should have an assertions.
Replace _Scheduler_Allocate() with _Scheduler_Node_initialize(). Remove
the return status and thus the node initialization must be always
successful.
Rename _Scheduler_Free() to _Scheduler_Node_destroy().
Extract code from _Scheduler_SMP_Enqueue_ordered() and move it to the
new function _Scheduler_SMP_Enqueue_scheduled_ordered() to avoid
untestable execution paths.
Add and use function _Scheduler_SMP_Unblock().
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Use the basic Scheduler_Context for the general SMP scheduler operations
to avoid usage of structure offsets to get the specialized context
variants.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
Add Thread_Control::is_in_the_air field if configured for SMP. This
helps to simplify the extract operation and avoids superfluous
inter-processor interrupts. Move the processor allocation step into the
enqueue operation.
Add and use _Scheduler_simple_smp_Get_highest_ready(). Add and use
_Scheduler_SMP_Get_lowest_scheduled().
Rename _Scheduler_simple_smp_Allocate_processor() to
_Scheduler_SMP_Allocate_processor().
Rename _Scheduler_simple_smp_Start_idle() to
_Scheduler_SMP_Start_idle().
Replace Scheduler_simple_smp_Control with Scheduler_SMP_Control. Rename
_Scheduler_simple_smp_Instance() to _Scheduler_SMP_Instance().
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
Use a per-CPU thread dispatch disable level. So instead of one global
thread dispatch disable level we have now one instance per processor.
This is a major performance improvement for SMP. On non-SMP
configurations this may simplifiy the interrupt entry/exit code.
The giant lock is still present, but it is now decoupled from the thread
dispatching in _Thread_Dispatch(), _Thread_Handler(),
_Thread_Restart_self() and the interrupt entry/exit. Access to the
giant lock is now available via _Giant_Acquire() and _Giant_Release().
The giant lock is still implicitly acquired via
_Thread_Dispatch_decrement_disable_level().
The giant lock is only acquired for high-level operations in interrupt
handlers (e.g. release of a semaphore, sending of an event).
As a side-effect this change fixes the lost thread dispatch necessary
indication bug in _Thread_Dispatch().
A per-CPU thread dispatch disable level greatly simplifies the SMP
support for the interrupt entry/exit code since no spin locks have to be
acquired in this area. It is only necessary to get the current
processor index and use this to calculate the address of the own per-CPU
control. This reduces the interrupt latency considerably.
All elements for the interrupt entry/exit code are now part of the
Per_CPU_Control structure: thread dispatch disable level, ISR nest level
and thread dispatch necessary. Nothing else is required (except CPU
port specific stuff like on SPARC).
Use an event triggered unicast to inform remote processors about a
necessary thread dispatch instead.
