* | rbtree: Format | Sebastian Huber | 2014-07-22 | 1 | -6/+7 |
* | score/rbtree: Remove "unprotected" from API | Sebastian Huber | 2013-11-21 | 1 | -2/+2 |
* | score/rbtree: Delete protected operations | Sebastian Huber | 2013-11-21 | 1 | -15/+0 |
| | | | | | The user of the red-black tree container must now ensure that at most one thread at once can access an instance. | ||||
* | score: Create rbtree implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | ||||
* | rbtree: API changes. Remove rbtree control node from RBTree_Next. | Gedare Bloom | 2012-05-08 | 1 | -8/+5 |
| | | | | | | | | | | | | The implementation of RBTree_Next was using an awkward construction to detect and avoid accessing the false root of the red-black tree. To deal with the false root, RBTree_Next was comparing node parents with the control node. Instead the false root can be detected by checking if the grandparent of a node exists; the grandparent of the tree's true root is NULL by definition so the root of the tree is found while walking up the tree by checking for the non-existence of a grandparent. This change propagates into the predecessor/successor and iterate functions. | ||||
* | rbtree: PR1995: API change | Sebastian Huber | 2012-04-11 | 1 | -0/+80 |
New functions o _RBTree_Next_unprotected(), o _RBTree_Next(), o _RBTree_Successor_unprotected(), o _RBTree_Predecessor_unprotected(), o rtems_rbtree_successor_unprotected(), and o rtems_rbtree_predecessor_unprotected(). Change prototype of o _RBTree_Successor(), o _RBTree_Predecessor(), o rtems_rbtree_successor(), and o rtems_rbtree_predecessor(). |
