Move implementation specific parts of chain.h and chain.inl into new
header file chainimpl.h. The chain.h contains now only the application
visible API.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
New macros
o _Objects_Maximum_per_allocation(),
o rtems_resource_is_unlimited(), and
o rtems_resource_maximum_per_allocation().
New function
o _Objects_Is_unlimited().
* score/src/objectinitializeinformation.c
(_Objects_Initialize_information): Remove unused var "name_length".
PR 1967/cpukit
* score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove
OBJECTS_NAME_ALIGNMENT and uses.
* score/src/objectinitializeinformation.c: Reverse sense of conditional
and improve comment. Comment was right but brief, conditional was
backwards.
* rtems/src/semtranslatereturncode.c,
score/src/coremutexsurrender.c,
score/src/objectinitializeinformation.c: Disable code not reachable
when POSIX is not enabled.
PR 1660/filesystem
* libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.h: Changed
int pipe_release to void pipe_release.
* libfs/src/imfs/imfs_fifo.c: Corresponding change to
IMFS_fifo_close since pipe_release does not return any error.
* libfs/src/imfs/imfs_initsupp.c: Changes to improve
IMFS_determine_bytes_per_block
* score/include/rtems/score/interr.h,
score/src/objectinitializeinformation.c: Add new fatal error for
configuring unlimited and maximum of 0.
Coverity Id 5
* score/src/objectinitializeinformation.c: Do not modify maximum
parameter. Clean up and simplify code. This should help the Coverity
path analysis to avoid reporting issues.
score/inline/rtems/score/object.inl,
score/src/objectgetnameasstring.c, score/src/objectidtoname.c,
score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c, score/src/thread.c,
score/src/threadcreateidle.c: Disable object string name support when
score/src/objectshrinkinformation.c: Eliminate name_table since it is
not used.
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_p.h,
libcsupport/src/malloc_report_statistics_plugin.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
score/src/objectinitializeinformation.c: Add posix_memalign. Split
out management of deferred frees to subroutines.
* libcsupport/src/malloc_deferred.c, libcsupport/src/posix_memalign.c: New files.
PR 753/rtems
score/src/objectinitializeinformation.c: Configured number of objects
needs to be of a type with more bits than Objects_Maximum to support
configuring unlimited objects. The type for configuring the maximum
number of objects should probably always be the same fundamental type
as Object Id. For 16-bit Id configurations, the constant
OBJECTS_UNLIMITED_OBJECTS was changed to 0x8000 to move in this
direction.
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
* score/include/rtems/score/object.h, score/src/object.c,
score/src/objectallocatebyindex.c, score/src/objectcomparenameraw.c,
score/src/objectinitializeinformation.c: Fix bugs in previous commit.
Now compiles.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/Makefile.am, include/rtems/score/coremsg.h,
include/rtems/score/coremutex.h, include/rtems/score/coresem.h,
include/rtems/score/object.h, include/rtems/score/threadq.h,
inline/rtems/score/object.inl, inline/rtems/score/thread.inl,
macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c,
src/coremutex.c, src/coresem.c, src/mpci.c,
src/objectcomparenameraw.c, src/objectextendinformation.c,
src/objectinitializeinformation.c, src/objectnametoid.c,
src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c,
src/threadqextractwithproxy.c: Modified as part of above.
* include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New
files.
