* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Split up objects allocation | Sebastian Huber | 2020-02-12 | 1 | -0/+44 |
Split up the different objects allocation methods into separate functions. This helps to avoid a dependency on the workspace in case no objects or a static set of objects is configured. Change license to BSD-2-Clause according to file histories. Update #3053. Update #3835. |
