Update #2555.
Update #2630.
In uni-processor configurations we have only one timehand. Do not issue
a memcpy() with equal source and destination.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2554.
Update #2502.
This reverts commit 46ae1d7a2b49b8f973dd6ba44fbbd38383798524.
The _Timecounter_Tick_simple() function actually doesn't switch to the
next timehand, so it is all right to use the simple timecounter approach
even on SMP configurations. The use of simple timecounters is not
recommended however since they impose a performance penalty.
When updating/accessing the timehands, barriers are needed to ensure
that:
- th_generation update is visible after the parameters update is
visible;
- the read of parameters is not reordered before initial read of
th_generation.
On UP kernels, compiler barriers are enough. For SMP machines, CPU
barriers must be used too, as was confirmed by submitter by testing on
the Freescale T4240 platform with 24 PowerPC processors.
Submitted by: Sebastian Huber <sebastian.huber@embedded-brains.de>
MFC after: 1 week
Implement a mechanism for making changes in the kernel<->driver PPS
interface without breaking ABI or API compatibility with existing drivers.
The existing data structures used to communicate between the kernel and
driver portions of PPS processing contain no spare/padding fields and no
flags field or other straightforward mechanism for communicating changes
in the structures or behaviors of the code. This makes it difficult to
MFC new features added to the PPS facility. ABI compatibility is
important; out-of-tree drivers in module form are known to exist. (Note
that the existing api_version field in the pps_params structure must
contain the value mandated by RFC 2783 and any RFCs that come along after.)
These changes introduce a pair of abi-version fields which are filled in
by the driver and the kernel respectively to indicate the interface
version. The driver sets its version field before calling the new
pps_init_abi() function. That lets the kernel know how much of the
pps_state structure is understood by the driver and it can avoid using
newer fields at the end of the structure that it knows about if the driver
is a lower version. The kernel fills in its version field during the init
call, letting the driver know what features and data the kernel supports.
To implement the new version information in a way that is backwards
compatible with code from before these changes, the high bit of the
lightly-used 'kcmode' field is repurposed as a flag bit that indicates the
driver is aware of the abi versioning scheme. Basically if this bit is
clear that indicates a "version 0" driver and if it is set the driver_abi
field indicates the version.
These changes also move the recently-added 'mtx' field of pps_state from
the middle to the end of the structure, and make the kernel code that uses
this field conditional on the driver being abi version 1 or higher. It
changes the only driver currently supplying the mtx field, usb_serial, to
use pps_init_abi().
Reviewed by: hselasky@
Use sbuf_printf() for sysctl strings instead of stack buffers and snprintf().
Add mutex support to the pps_ioctl() API in the kernel.
Bump kernel version to reflect structure change.
PR: 196897
MFC after: 1 week
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
New test sptests/timecounter01.
Update #2271.
Update #2271.
FreeBSD assumes that u_int is a 32-bit integer type. This is wrong for
some 16-bit targets supported by RTEMS.
Update #2271.
Update #2271.
