* | score: Introduce _Internal_error() | Sebastian Huber | 2016-12-12 | 1 | -4/+1 |
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | score: Statically initialize _ISR_Vector_table | Sebastian Huber | 2014-04-29 | 1 | -4/+8 |
* | score: Use common names for per-CPU variables | Sebastian Huber | 2014-04-22 | 1 | -8/+8 |
| | | | | | | | | | | | | | | | | Use "cpu" for an arbitrary Per_CPU_Control variable. Use "cpu_self" for the Per_CPU_Control of the current processor. Use "cpu_index" for an arbitrary processor index. Use "cpu_index_self" for the processor index of the current processor. Use "cpu_count" for the processor count obtained via _SMP_Get_processor_count(). Use "cpu_max" for the processor maximum obtained by rtems_configuration_get_maximum_processors(). | ||||
* | score: Rename _Internal_error_Occurred() | Sebastian Huber | 2014-02-21 | 1 | -1/+1 |
| | | | | Rename _Internal_error_Occurred() into _Terminate(). | ||||
* | score: Move SMP interrupt stack initialization | Sebastian Huber | 2014-02-19 | 1 | -18/+25 |
| | | | | | | | Move SMP interrupt stack initialization for secondary processors from _SMP_Handler_initialize() to _ISR_Handler_initialization() to avoid code duplication. Apply _CPU_Interrupt_stack_setup() to all interrupt stacks. | ||||
* | smp: Delete _ISR_SMP_Initialize() | Sebastian Huber | 2013-07-30 | 1 | -4/+0 |
* | score: Create stack implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of stack.h and stack.inl into new header file stackimpl.h. The stack.h contains now only the application visible API. | ||||
* | score: Include missing <rtems/score/address.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
* | Score misc: Clean up Doxygen #4 (GCI 2012) | Alexandre Devienne | 2012-11-28 | 1 | -10/+2 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7985215 | ||||
* | sapi: Use rtems_config*_get_interrupt_stack_size | Sebastian Huber | 2012-11-07 | 1 | -14/+17 |
* | isr.c: Do not call _CPU_Initialize_vectors() if PIC Interrupt Model | Joel Sherrill | 2012-06-11 | 1 | -5/+8 |
* | 2011-08-22 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-08-22 | 1 | -0/+3 |
| | | | | | | | | PR 1876 * score/Makefile.am, score/include/rtems/score/isr.h, score/src/isr.c, score/src/smp.c, score/src/smplock.c, score/src/threaddispatch.c, score/src/threaddispatchdisablelevel.c: Add smp isr support. * score/src/isrsmp.c: New file. | ||||
* | 2011-02-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-01 | 1 | -0/+2 |
| | | | | | | PR 1733/cpukit * score/src/isr.c: If target architecture does nto require stack initialization, then do not perform adjustment. | ||||
* | 2010-08-19 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-08-19 | 1 | -1/+1 |
| | | | | | | | | PR 1680/cpukit * score/src/isr.c: Correct initialization of _CPU_Interrupt_stack_high to properly do the alignment. This most likely only would have caused a propblem on CPUs where the stack grows down and have strict alignment. | ||||
* | 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 1 | -2/+3 |
| | | | | | | | | | | | | | | | | | | | PR 1573/cpukit * configure.ac, posix/src/killinfo.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c, posix/src/pthreadkill.c, posix/src/pthreadsigmask.c, rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am, score/preinstall.am, score/include/rtems/system.h, score/include/rtems/score/context.h, score/include/rtems/score/isr.h, score/include/rtems/score/thread.h, score/src/isr.c, score/src/isrthreaddispatch.c, score/src/thread.c, score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. * score/include/rtems/score/percpu.h, score/src/percpu.c: New files. | ||||
* | 2009-10-29 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-29 | 1 | -0/+7 |
| | | | | | | * score/src/isr.c: Check if CPU defined _CPU_Interrupt_stack_setup() macro hook for setting up the interrupt stack (alignment, reserving space etc.) after the framework allocates it. | ||||
* | Eliminate TRUE/FALSE. | Ralf Corsepius | 2008-12-22 | 1 | -2/+2 |
* | 2008-12-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-15 | 1 | -4/+4 |
| | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c, posix/include/rtems/posix/config.h, posix/include/rtems/posix/posixapi.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/wkspace.c: Eliminate pointers to API configuration tables in the main configuration table. Reference the main configuration table and the API configuration tables directly using the confdefs.h version rather than obtaining a pointer to it. This eliminated some variables, a potential fatal error, some unnecessary default configuration structures. Overall, about a 4.5% reduction in the code size for minimum and hello on the SPARC. | ||||
* | 2008-06-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-06-13 | 1 | -1/+1 |
| | | | | | | | | | | | | | * posix/include/rtems/posix/pthread.h, posix/src/pthread.c, posix/src/pthreadcreate.c, rtems/include/rtems.h, rtems/src/attr.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, score/inline/rtems/score/stack.inl, score/src/isr.c, score/src/mpci.c, score/src/threadcreateidle.c, score/src/threadinitialize.c, score/src/threadstackallocate.c: Add ability for application to configure minimum stack size. Add RTEMS_CONFIGURED_MINIMUM_STACK_SIZE constant so user can clearly indicate they want the configured as opposed to the recommended minimum stack size. | ||||
* | 2008-06-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-06-05 | 1 | -0/+2 |
| | | | | | | * score/include/rtems/score/isr.h, score/src/isr.c: Use CPU_SIMPLE_VECTORED_INTERRUPTS porting parameter to avoid allocating memory for vector table. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 1 | -4/+6 |
| | | | | | | | | | * sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/src/exinit.c, score/include/rtems/system.h, score/src/isr.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | Include config.h. | Ralf Corsepius | 2005-01-27 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed. | ||||
* | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-01-03 | 1 | -0/+2 |
| | | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors(). | ||||
* | 2000-12-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-19 | 1 | -4/+4 |
| | | | | | * src/isr.c: Allocate the _ISR_Vector_table all the time not just when we are allocating an interrupt stack. | ||||
* | 2000-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-13 | 1 | -0/+4 |
| | | | | | | * include/rtems/score/isr.h, src/isr.c: Allocate it from the workspace rather than explicitly declaring it. This allows the size to be a non-constant from the perspective of score/cpu. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -4/+4 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -0/+60 |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. |
