This enables fatal extensions to continue program execution after some
fatal errors.
This partially reverts 38ee75853f674977609bd078c69fb53420afdd08. Let
the calling context decide if interrupts must be disabled or not. The
goal is to enable fatal extensions to continue program execution after
some fatal errors.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
This is a preparation to remove the Giant lock.
Update #2555.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into
_SMP_Request_start_multitasking() since this requests now a multitasking
start on all configured and available processors. The name corresponds
_Thread_Start_multitasking() and
_SMP_Start_multitasking_on_secondary_processor() actions issued in
response to this request. Move in source file to right place.
Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into
PER_CPU_STATE_READY_TO_START_MULTITASKING.
Rename PER_CPU_STATE_BEGIN_MULTITASKING into
PER_CPU_STATE_REQUEST_START_MULTITASKING.
Rename _SMP_Request_other_cores_to_shutdown() into
_SMP_Request_shutdown().
Add a per-CPU state lock to protect all changes. This was necessary to
offer a controlled shutdown of the system (atomic read/writes alone are
not sufficient for this kind of synchronization).
Add documentation for Per_CPU_State.
Delete debug output.
New tests smptests/smpfatal01 and smptests/smpfatal02.
Rename _Internal_error_Occurred() into _Terminate().
Collect SMP implementation specific parts in the
<rtems/score/smpimpl.h> header file.
Move _SMP_Request_other_cores_to_shutdown() invocation from
rtems_shutdown_executive() to _Internal_error_Occurred() to allow a
proper shutdown on SMP configurations even in the error case.
Disable interrupts as the first step in _Internal_error_Occurred() to
get a defined execution context for the fatal extensions.
Make _ISR_Disable_without_giant() available for non-SMP configurations.
Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into
new system state SYSTEM_STATE_TERMINATED. This reflects that all system
termination paths end up in _Internal_error_Occurred().
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
Call the fatal handlers of the user extensions before the update of
_Internal_errors_What_happened. This reduces the requirements on the
execution context further. Now a valid read-write data is only required
after the call to the fatal handlers.
This reverts commit 7d0bdcac1ac20d6f22b24689c16e6aa7bc3c1e40.
Add Internal_errors_Information::nest_level. This helps to detect
recursive calls to _Internal_error_Occurred().
Define _System_state_Current and _Internal_errors_What_happened in
interr.c to make _Internal_error_Occurred() more independent.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* score/include/rtems/score/interr.h, score/src/interr.c: Convention
calls for leading underscore on private RTEMS variables.
* sapi/src/fatal.c, score/src/interr.c:
Remove volatile on return type.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
like signal dispatching.
