* macros/rtems/score/coresem.inl: Removed comments since convention
calls for comments to be in inline versin.
* macros/rtems/score/object.inl (Objects_Get_local_object): Fixed
style to use _ prefix on variable names and use parentheses.
* macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
* General effort to make things compile with macros not inlines
* inline/rtems/score/coremutex.inl: Added comment indicating
for macros there is another copy of
_CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c.
* src/coremutexseize.c: Added body of
_CORE_mutex_Seize_interrupt_trylock() for macro case.
* macros/rtems/score/coremutex.inl: Added prototype for
_CORE_mutex_Seize_interrupt_trylock() since there is a real
body when macros are enabled.
* macros/rtems/score/coresem.inl: Added macro implementation of
_CORE_semaphore_Seize_isr_disable.
* macros/score/Makefile.am: Fixed typos.
* rtems/score/address.inl: Correct macro implementation of
_Addresses_Is_aligned() so it would compile.
* macros/rtems/score/coremsg.inl: Added closing parentheses.
were done by Joel.
are:
not a valid object class. This was discovered while looking for
a bug reported by Jennifer.
as the sole statement in an if or else statement
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
correct Information block.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
