* score/include/rtems/score/wkspace.h, score/src/wkstringduplicate.c:
Changed parameter of _Workspace_String_duplicate() to avoid strnlen().
* score/src/wkstringduplicate.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/wkspace.h: Declare
_Workspace_String_duplicate().
* score/src/heapiterate.c, score/src/pheapiterate.c: New files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define
Heap_Block_visitor.
* score/include/rtems/score/protectedheap.h: Declare
_Protected_heap_Iterate().
* score/src/heapgetinfo.c: Use _Heap_Iterate().
PR 1967/cpukit
* score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove
OBJECTS_NAME_ALIGNMENT and uses.
PR 1941/cpukit
* libmisc/monitor/mon-server.c, score/include/rtems/system.h: Remove
use of RTEMS_offset() in favor of standard offsetof(). This was
undocumented and there was only one internal use. Change noted in
4.11 release notes.
PR 1963
* score/include/rtems/score/rbtree.h: Fix _RBTree_Container_of macro to
use correct arithmetic.
PR 1957/cpukit
* score/include/rtems/score/coremutex.h,
score/inline/rtems/score/threadmp.inl: Add parentheses to protect
macro arguments.
* score/include/rtems/score/rbtree.h (_RBTree_Container_of):
Use offsetof. Don't cast to size_t. Include <stddef.h>.
PR 1935/cpukit
* score/include/rtems/score/smplock.h, score/src/smplock.c: SMP nested
count variable was being overritten when nested lock was taken more
than once.
PR 1938/cpukit
* score/include/rtems/score/thread.h: Removed obsolete suspend_count
field from Thread_Control.
PR 1922
* score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c:
EDF and CBS scheduler: extern declarations fix.
* score/include/rtems/score/tod.h: Declare _TOD_Set_with_timestamp()
and _TOD_Get_as_timestamp().
* score/src/coretodset.c: Define _TOD_Set_with_timestamp().
* score/src/coretodget.c: Define _TOD_Get_as_timestamp().
* rtems/src/clockset.c: Use _TOD_Set_with_timestamp().
* score/include/rtems/score/timestamp64.h, score/src/ts64set.c:
Changed parameter types of _Timestamp64_Set().
* rtems/src/clocktodtoseconds.c: Year 2100 is not a leap year.
PR 1914/cpukit
* score/src/timespecgreaterthan.c, score/src/ts64greaterthan.c:
Removed files.
* score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64divide.c, score/src/ts64dividebyinteger.c,
score/src/ts64equalto.c, score/src/ts64getnanoseconds.c,
score/src/ts64getseconds.c, score/src/ts64lessthan.c,
score/src/ts64set.c, score/src/ts64settozero.c,
score/src/ts64subtract.c, score/src/ts64toticks.c,
score/src/ts64totimespec.c: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
CPU_TIMESTAMP_USE_INT64, and CPU_TIMESTAMP_USE_INT64_INLINE. Removed
copy and paste.
* score/include/rtems/score/thread.h: Ensure CBS builds with POSIX
disabled.
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbsattachthread.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
PR 1898/cpukit
* score/include/rtems/score/percpu.h: Use CPU_STRUCTURE_ALIGNMENT for
_Per_CPU_Information.
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
PR 1873/cpukit
* score/include/rtems/score/heap.h: Revert previous commit.
* sapi/include/confdefs.h: Use proper constants in
_Configure_From_workspace().
* score/include/rtems/score/basedefs.h: Typo.
* score/src/mpci.c, rtems/src/eventmp.c, rtems/src/msgmp.c,
rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskmp.c: Use RTEMS_STATIC_ASSERT() to
ensure that the packet size is small enough.
PR 1895/cpukit
* rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, sapi/include/confdefs.h,
score/Makefile.am, score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/coremutexseize.c: Add priority_compare and release_job
hooks interfaces to scheduler interface.
* score/src/schedulerpriorityprioritycompare.c,
score/src/schedulerpriorityreleasejob.c: New files.
PR 1876
* score/Makefile.am, score/include/rtems/score/isr.h, score/src/isr.c,
score/src/smp.c, score/src/smplock.c, score/src/threaddispatch.c,
score/src/threaddispatchdisablelevel.c: Add smp isr support.
* score/src/isrsmp.c: New file.
PR 1886/cpukit
* sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl,
score/include/rtems/score/rbtree.h,
score/inline/rtems/score/rbtree.inl, score/src/rbtree.c,
score/src/rbtreeinsert.c: This patch enables inserting duplicate keys
into rbtree. It is possible to turn on this feature when initializing
the tree.
PR 1873/cpukit
* score/include/rtems/score/heap.h: When using heap protection, we
should account for adding an aligned protection footer.
PR 1877/cpukit
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/memfile.c,
sapi/inline/rtems/rbtree.inl, score/include/rtems/score/rbtree.h,
score/src/rbtreefind.c, score/src/rbtreeinsert.c: Add comparison
function for RBTrees.
* score/include/rtems/score/coremutex.h: Move check dispatch for seize
into its own macro and add smp support.
* score/include/rtems/score/isr.h: Cleaned up comments.
* score/include/rtems/score/smplock.h: Fix comments.
* score/include/rtems/score/mppkt.h: Remove extra spaces.
PR 1842/cpukit
* score/include/rtems/score/basedefs.h: Added RTEMS_STATIC_ASSERT().
* score/include/rtems/score/chain.h: Fix typo.
* score/Makefile.am, score/preinstall.am,
score/include/rtems/score/isr.h, score/include/rtems/score/percpu.h:
Split isrlevel into its own file to avoid a circular dependancy in
smp code.
* score/include/rtems/score/isrlevel.h: New file.
* score/Makefile.am, score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmptick.c: Build schedulersimplesmptick.c
and fix typos.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* Doxyfile.in, score/include/rtems/score/apimutex.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/object.h: Fix some Doxygen warnings.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
PR 1796/cpukit
* sapi/src/exshutdown.c, score/include/rtems/score/percpu.h,
score/include/rtems/score/smp.h, score/src/smp.c,
score/src/threaddispatch.c, score/src/threadhandler.c: Added SMP
interprocess communications.
* score/Makefile.am, score/include/rtems/score/thread.h,
score/inline/rtems/score/thread.inl: Add smp support to dispable
dispatch level accesses.
* score/src/threaddispatchdisablelevel.c: New file.
PR 1787/cpukit
* score/include/rtems/score/percpu.h,
score/include/rtems/score/smplock.h, score/src/smp.c,
score/src/smplock.c: Add nesting support to smp spinlock.
PR 1789/cpukit
Simple SMP Priority Scheduler.
* score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmpblock.c,
score/src/schedulersimplesmpschedule.c,
score/src/schedulersimplesmpunblock.c: New files.
* score/include/rtems/score/schedulersimple.h,
score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleunblock.c: Correct names as pointed out by
Gedare.
PR 1788/cpukit
score/include/rtems/score/thread.h: Make time of last context switch
part of per cpu information since each core has a different context
switch to track.
* score/Makefile.am, score/include/rtems/score/isr.h: Replace tabs with
spaces.
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/threadcreateidle.c: Modifications to restrict compilation
of SMP only code to when SMP is enabled. Entire SMP specific files
are disabled via Makefile.am.
PR 1784
* sapi/src/exinit.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/bspsmp.h, score/src/percpu.c, score/src/smp.c,
score/src/threadcreateidle.c: Split bspsmp.h into two files smp.h and
bspsmp.h
* score/include/rtems/score/smp.h: New file.
* score/include/rtems/bspsmp.h: Did some prototype cleanup.
PR 1782/cpukit
* score/include/rtems/score/thread.h: Disable deferred FPU context
switches when SMP is enabled. Per code tracking of deferred contexts
is not implemented.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
