* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* score/include/rtems/score/sysstate.h,
score/inline/rtems/score/sysstate.inl, score/src/thread.c: Make
_System_state_Is_multiprocessing unused when multiprocessing is not
enabled. Saves one more variable from single processor configuration.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
PR 1265/cpukit
* score/include/rtems/score/object.h,
score/src/objectallocatebyindex.c: Rename index argument to avoid
warning when rtems.h and string.h are included at the same time by
user code.
PR 1291/cpukit
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/include/mqueue.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/time.h, posix/src/condtimedwait.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mutextimedlock.c, posix/src/mutextranslatereturncode.c,
posix/src/posixtimespecabsolutetimeout.c,
posix/src/semaphoretranslatereturncode.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semtrywait.c, posix/src/semwait.c,
posix/src/sigtimedwait.c, posix/src/timersettime.c,
posix/src/ualarm.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: This
patch addresses issues on implementation of the timeout on the
following POSIX services. Some of these services incorrectly took a
timeout as a relative time. Others would compute a 0 delta to timeout
if the absolute time and the current time were equal and thus
incorrectly block the caller forever. The root of the confusion is
that POSIX specifies that if the timeout is incorrect (e.g. in the
past, is now, or is numerically invalid), that it does not matter if
the call would succeed without blocking. This is in contrast to RTEMS
programming style where all errors are checked before any critical
sections are entered. This fix implemented a more uniform way of
handling POSIX absolute time timeouts.
+ pthread_cond_timedwait - could block forever
+ mq_timedreceive - used relative not absolute time
+ mq_timedsend - used relative not absolute time
+ pthread_mutex_timedlock - used relative not absolute time
+ pthread_rwlock_timedrdlock- used relative not absolute time
+ pthread_rwlock_timedwrlock- used relative not absolute time
+ sem_timedwait - could block forever
* sapi/include/confdefs.h, score/include/rtems/score/priority.h: Add
CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY.
* score/include/rtems/score/priority.h: Let the CPU define the
maximum and minimum priority levels to reduce the amount of memory
thread chains use.
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonperiod.c,
score/include/rtems/score/thread.h: Complete previous patch. Add
typedef for cpu usage statistics.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-task.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, score/include/rtems/score/thread.h,
score/src/threaddispatch.c, score/src/threadinitialize.c,
score/src/threadtickletimeslice.c: Add typedefs for cpu usage and
period timing statistics. Also renamed related variables and
structure members so they are the same whether you are using
nanosecond (e.g. struct timespec) or ticks (e.g. uint32_t)
granularity. This lays the groundwork for future cleanup.
* score/include/rtems/score/isr.h, score/src/isr.c: Use
CPU_SIMPLE_VECTORED_INTERRUPTS porting parameter to avoid allocating
memory for vector table.
* score/include/rtems/score/interr.h, score/src/interr.c: Convention
calls for leading underscore on private RTEMS variables.
and RTEMS_ID_NONE. No object can have this ID.
* score/include/rtems/system.h: Fix typo in comment.
* score/include/rtems/score/tod.h: Fix typo.
* score/include/rtems/score/copyrt.h: Update year.
* posix/src/mqueueunlink.c, score/Makefile.am,
score/inline/rtems/score/object.inl: Enhance
_Objects_Namespace_remove() to handle freeing object names which are
strings. All changed _Objects_Close() to call
_Objects_Namespace_remove(). The resulting code was then moved from
inline routines to function calls.
* score/src/objectclose.c, score/src/objectnamespaceremove.c: New files.
* posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c,
posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c,
posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c,
posix/src/semaphorenametoid.c: Add option for all POSIX objects
whether named or unnamed to have a string name. If the API does
not directly support having a name, then the user must explicitly
assign it using rtems_object_set_name().
* rtems/src/rtemsobjectgetapiclassname.c: Improved testability.
score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c: Modifications required to pass testing of
recently modified object name operations. Also eliminated
multiprocessing related code that was not reachable.
* score/include/rtems/score/object.h, score/src/objectgetinfo.c,
rtems/include/rtems/rtems/object.h,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetclassinfo.c: class is a C++ keyword and
cannot be used as a parameter.
* score/Makefile.am, score/include/rtems/score/threadq.h,
score/inline/rtems/score/threadq.inl: _Thread_queue_Process_timeout
was really too complex to be inlined.
* score/src/threadqprocesstimeout.c: New file.
* score/Doxyfile: Update to latest Doxygen format.
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/heap.h, score/include/rtems/score/object.h,
score/include/rtems/score/protectedheap.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/tod.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Remove most doxygen
warnings.
* score/include/rtems/system.h: First cut at Doxygen mainpage.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* sapi/include/rtems/fatal.h, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/thread.inl, score/src/coremutexseize.c:
Modifications to aid in full path testing.
score/src/objectextendinformation.c,
score/src/objectinitializeinformation.c,
score/src/objectshrinkinformation.c: Eliminate name_table since it is
not used.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* rtems/include/rtems/rtems/event.h,
rtems/inline/rtems/rtems/eventset.inl, rtems/src/event.c,
rtems/src/eventseize.c, rtems/src/eventsurrender.c,
rtems/src/eventtimeout.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/tqdata.h,
score/inline/rtems/score/threadq.inl,
score/inline/rtems/score/tqdata.inl, score/src/threadq.c,
score/src/threadqtimeout.c: Refactor thread queue enqueue and event
blocking synchronization critical sections. This resulted in three
copies of essentially the same hard to test critical section code
becoming the one shared routine _Thread_blocking_operation_Cancel. In
addition, the thread queue and event code now share a common
synchronization enumerated type. Along the way, switches were
reworked to eliminate dead code generated by gcc and comments and
copyrights were updated.
* score/include/rtems/score/threadsync.h,
score/src/threadblockingoperationcancel.c: New files.
* posix/include/rtems/posix/timer.h, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/mqueueclose.c,
posix/src/timergettime.c, posix/src/timersettime.c,
score/include/rtems/score/timespec.h:
* score/include/rtems/score/wkspace.h,
score/inline/rtems/score/wkspace.inl, score/src/wkspace.c: Do not
inline _Workspace_Free or _Workspace_Allocate since they are not
always inlined and actually smaller overall as subroutines. They are
not particularly time critical so inlining is not absolutely
necessary.
* score/include/rtems/score/coremutex.h,
score/src/coremutexseizeintr.c: Fix conditional code for inlining
_CORE_mutex_Seize_interrupt_trylock() and add comments.
* posix/src/keycreate.c, rtems/src/eventseize.c,
score/include/rtems/score/interr.h: Rearranged source to allow more
test coverage.
* configure.ac, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl: Add the ability to disable
inlining coremutex seize. This reduces the code size and also
improves the process of coverage analysis.
* score/src/coremutexseizeintr.c: New file.
score/inline/rtems/score/coremutex.inl,
score/src/coremutexsurrender.c, score/src/threadinitialize.c: Add
support for proper stacking of priority inheritance on mutexes as
well as enforce proper order of release.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c,
score/include/rtems/system.h, score/src/isr.c: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* sapi/src/exinit.c, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/src/object.c,
score/src/thread.c: Conditionally compile out more code that is
specific to multiprocessor configurations.
* score/include/rtems/score/thread.h: Fix spelling error.
* sapi/src/exinit.c, score/Makefile.am,
score/include/rtems/score/apimutex.h: API Mutex calls should never
have been inlined. Inlining them lead to many inlined copies of core
mutex lock. This lead to over 2K savings in the SPARC/ERC32
minimum.exe.
* score/src/apimutex.c, score/src/apimutexallocate.c,
score/src/apimutexlock.c, score/src/apimutexunlock.c: New files.
* score/include/rtems/score/isr.h: added RTEMS_COMPILER_MEMORY_BARRIER
around _CPU_ISR_Set_level().
* score/include/rtems/system.h, score/include/rtems/score/interr.h: Add
compiler conditional attribute for methods that do not return. This
avoids gcc generating unreachable code following calls to
_Internal_error_Occurred.
Miscellaneous changes made after a review against the POSIX spec.
* posix/src/pbarrierinit.c, posix/src/prwlockinit.c: If the caller
passes a NULL in the attributes parameter, default attributes are used.
* posix/src/prwlockdestroy.c: If there is at least one thread
waiting, do not allow deletion.
* posix/src/prwlockwrlock.c: Corrected parameter passed to the core
operation used to obtain a RWLock for writing.
* posix/src/pspinlocktranslatereturncode.c,
score/include/rtems/score/corespinlock.h,
score/src/corespinlockrelease.c: If the current thread is not the
holder of the lock, do not allow an unlock and return EPERM.
* score/src/corerwlockobtainwrite.c: Corrected to use the operation
for queueing with a timeout handler.
* score/cpu/sparc/cpu.c, score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/context.h, score/src/threadhandler.c: Fix
stack so gdb backtrace does not print corrupted frame message after
_Thread_Handler. Daniel Hellstrom <daniel@gaisler.com> provided the
SPARC implementation and I made it more general.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
