PR 1941/cpukit
* libmisc/monitor/mon-server.c, score/include/rtems/system.h: Remove
use of RTEMS_offset() in favor of standard offsetof(). This was
undocumented and there was only one internal use. Change noted in
4.11 release notes.
* score/include/rtems/score/basedefs.h: New file.
* score/Makefile.am, score/preinstall.am: Reflect change above.
* score/include/rtems/score/percpu.h: Include <rtems/score/cpu.h>.
* score/include/rtems/system.h: Moved definition of SCORE_EXTERN,
SAPI_EXTERN, RTEMS_EXTERN, POSIX_EXTERN, RTEMS_INLINE_ROUTINE,
RTEMS_COMPILER_MEMORY_BARRIER, RTEMS_COMPILER_NO_RETURN_ATTRIBUTE,
RTEMS_COMPILER_DEPRECATED_ATTRIBUTE, TRUE, and FALSE to
<rtems/score/basedefs.h>.
Removed include of <rtems/score/cpu.h>, <stdint.h> and <stddef.h>.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* score/include/rtems/system.h: Remove ITRON_EXTERN.
* score/include/rtems/system.h: Let RTEMS_offsetof return uintptr_t
instead of uint32_t (16bit target compatibility).
* score/include/rtems/system.h: Fix warnings about TRUE/FALSE not
defined on ARM target. This file need to be clean from .S files.
* score/include/rtems/system.h: Added
RTEMS_COMPILER_DEPRECATED_ATTRIBUTE define.
* Doxyfile.in, rtems/mainpage.h, score/include/rtems/system.h: Move to
generating Doxygen for more of CPU Kit.
* rtems/Doxyfile, score/Doxyfile, score/mainpage.h: Removed.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* score/include/rtems/system.h: Fix typo in comment.
* score/include/rtems/system.h: First cut at Doxygen mainpage.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c,
score/include/rtems/system.h, score/src/isr.c: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* score/include/rtems/system.h, score/include/rtems/score/interr.h: Add
compiler conditional attribute for methods that do not return. This
avoids gcc generating unreachable code following calls to
_Internal_error_Occurred.
__RTEMS_MINOR__, __RTEMS_REVISION__ (moved to cpuopt.h).
#define __RTEMS_MINOR__ 7 (BZ 1206).
* configure.ac, itron/Makefile.am, itron/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
PR 866/rtems
* score/include/rtems/system.h, score/include/rtems/score/isr.h,
score/inline/rtems/score/thread.inl,
score/macros/rtems/score/thread.inl: Added memory barriers to enter
and exit of dispatching and interrupt critical sections so GCC will
not optimize and reorder code out of a critical section.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
PR 742/rtems
* score/include/rtems/system.h: Remove stringify().
* score/include/rtems/system.h: Don't define NULL, include
<stddef.h>.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* score/src/coremsg.c: Eliminate unsigned32.
* score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99.
* librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* rtems/include/rtems/rtems/types.h: Include <rtems/stdint.h>
instead of <stdint.h>.
Conditionally typedef rtems*signed64 types.
* score/include/rtems/system.h: Include <rtems/stdint.h> instead of
<stdint.h>.
* score/include/rtems/system.h: include <stdint.h>.
PR 525/rtems
* include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES.
* include/rtems/score/chain.h: Ditto.
* include/rtems/score/thread.h: Ditto.
* src/chain.c: Ditto.
* src/coremutexseize.c: Ditto.
* src/threadget.c: Ditto.
* include/rtems/system.h: Remove targopts.h.
* include/rtems/system.h: Add the sparc to the target supporting
multlibs.
* include/rtems/system.h: Add i386 to multilib-able targets.
* include/rtems/system.h: Fix typo in yesterday's change:
RTEMS_MULTILIBS.
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
* include/rtems/system.h: Include cpuopts.h for __i386__.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
using cpuopts.h and not targopts.h.
that addresses aspects of the targopts.h multilib related
issues.
* Move targopts.h to libbsp/include, because the current targopts.h
actually is a per-BSP-header and therefore can not stay below exec/.
* Introduce an autoheader generated header file
(exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu
configuration options only.
* Move all autoconf-detectable/configure specified per-cpu
option-defines from targopts.h to cpuopts.h.
* Add Makefiles to the libbsp/shared directory hierarchy.
* The new per-bsp targopts.h in libbsp includes the per-cpu
cpuopts.h. This way, the new targopts.h is kept backward compatible
to the old targopts.h and existing BSPs which (carelessly) include
targopts.h (i386, ppc) should be kept working when using the
multilib-disabled configuration scheme.
* cpuopts.h is not yet complete, because the per-BSP make-targopts
rules from custom/<BSP>.cfg files can not be applied to files below
exec/ when building multilibs.
* All files below exec/ should not include targopts.h anymore, but
should include cpuopts.h instead. However, eliminating inclusion of
targopts.h currently triggers further structural / header file inclusion
related issues, because several ports apply BSP or CPU_MODEL specific
defines from targopts.h below exec/
