* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 6 | -3/+15 |
| | | | | * rtems/score/cpu.h: Remove extraneous spaces. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -4/+8 |
| | | | | * cpu.c, rtems/score/cpu.h: Remove extraneous spaces. | ||||
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+5 |
| | | | | | * Makefile.am: Merge thumb/Makefile.am. * thumb/Makefile.am: Remove (superfluous). | ||||
* | Merge thumb/Makefile.am. | Ralf Corsepius | 2008-09-07 | 1 | -3/+2 |
* | Remove (superfluous). | Ralf Corsepius | 2008-09-07 | 1 | -14/+0 |
* | Stop using old-style defs. | Ralf Corsepius | 2008-09-05 | 1 | -2/+2 |
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * cpu.c: Stop using old-style defs. | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 3 | -0/+12 |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 10 | -28/+28 |
| | | | | * rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Convert to "bool". | ||||
* | 2008-08-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-21 | 1 | -0/+6 |
| | | | | | | * rtems/score/avr.h: Add avr25, avr31, avr35, avr51 to CPU_NAME cascade. * rtems/score/cpu.h: Add missing prototypes.h. | ||||
* | Add avr25, avr31, avr35, avr51 to CPU_NAME cascade. | Ralf Corsepius | 2008-08-21 | 1 | -0/+16 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-21 | 1 | -1/+1 |
* | 2008-08-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-21 | 14 | -0/+70 |
| | | | | | * rtems/score/types.h: Include stdbool.h. Use bool as base-type for boolean. | ||||
* | Include stdbool.h. Use bool as base-type for boolean. | Ralf Corsepius | 2008-08-21 | 14 | -14/+28 |
* | 2008-08-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-20 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Correct prototype of _CPU_Thread_dispatch_pointer. | ||||
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 3 | -24/+27 |
| | | | | | | * cpu.c: Fix prototypes. * rtems/score/cpu.h: Use memcpy() initialize FP structure and avoid many casts and potential warnings. | ||||
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 2 | -4/+8 |
| | | | | * rtems/score/cpu.h: Fix type when initializing FP context. | ||||
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 3 | -7/+17 |
| | | | | | * cpu.c, rtems/score/cpu.h: Add extern for bfffo table and rename it to indicate that it is specific to this architecture. | ||||
* | 2008-08-19 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-19 | 1 | -0/+4 |
| | | | | * rtems/score/cpu.h: Add missing prototype. | ||||
* | Add missing prototype. | Ralf Corsepius | 2008-08-19 | 1 | -1/+1 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-19 | 2 | -4/+4 |
* | 2008-08-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-18 | 3 | -2/+6 |
| | | | | * cpu.c, rtems/score/cpu.h: Add void. | ||||
* | 2008-08-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-16 | 1 | -0/+4 |
| | | | | * rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-16 | 2 | -4/+4 |
* | Cosmetic indentation fixes. | Ralf Corsepius | 2008-08-16 | 1 | -7/+7 |
* | 2008-08-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-15 | 1 | -0/+10 |
| | | | | * ChangeLog: Add correct entry. | ||||
* | 2008-08-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-14 | 5 | -534/+631 |
| | | | | | | | * rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/status.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/object.h: Removed extraneous commas. | ||||
* | 2008-08-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-14 | 2 | -8/+11 |
| | | | | | * rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL and MSR_USER. Added missing prototypes. | ||||
* | 2008-08-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-05 | 2 | -1/+7 |
| | | | | | | * rtems/new-exceptions/cpu.h: Changed define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison between signed and unsigned. | ||||
* | 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-04 | 3 | -38/+9 |
| | | | | | | PR 1294/bsps * rtems/score/cpu.h, rtems/score/sparc.h: Correct prototype and usage of sparc_disable_interrupts. | ||||
* | 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-04 | 2 | -0/+5 |
| | | | | * rtems/score/cpu.h: Spacing. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 27 | -19/+56 |
| | | | | * cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 6 | -3/+15 |
| | | | | * rtems/score/cpu.h: Correct prototype of Idle threads. | ||||
* | Changed special purpose register inline functions to macros. | Thomas Doerfler | 2008-07-18 | 2 | -0/+8 |
| | | | | | fixed some minors in mpc83xx support added file for mpc55xx watchdog support | ||||
* | 2008-07-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-07-16 | 1 | -2/+2 |
| | | | | | | * score/cpu/powerpc/rtems/new-exceptions/cpu.h: use ppc_interrupt_get_disable_mask() to determine which bits to set/clear from _CPU_ISR_Set_level(). | ||||
* | 2008-07-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-07-16 | 1 | -0/+10 |
| | | | | | * score/cpu/powerpc/rtems/powerpc/registers.h: added ppc_interrupt_get_disable_mask() inline function. | ||||
* | added haleakala BSP contributed by Michael Hamel | Thomas Doerfler | 2008-07-14 | 2 | -0/+7 |
* | added support for mcf548x | Thomas Doerfler | 2008-07-11 | 4 | -2/+183 |
* | adapted for modified exception code | Thomas Doerfler | 2008-07-11 | 4 | -40/+117 |
* | 2008-07-10 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-07-10 | 3 | -439/+37 |
| | | | | | | | | | | | * cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h, cpukit/score/cpu/powerpc/rtems/score/cpu.h, cpukit/score/cpu/powerpc/rtems/score/powerpc.h: Removed all macro definitions which depended on the compiler defining a PPC CPU-model dependent symbol. Macros which were not used by cpukit have been moved to libcpu/powerpc/rtems/powerpc/powerpc.h. | ||||
* | added irq-extension.h declarations | Thomas Doerfler | 2008-07-10 | 2 | -0/+11 |
* | hris Johns <chrisj@rtems.org> | Chris Johns | 2008-06-16 | 1 | -0/+1 |
| | | | | | | | | * cpukit/sapi/include/confdefs.h: Add missing quote to string to remove warning. * cpukit/score/cpu/m68k/rtems/score/m68k.h: Add the default priority level for large memory Coldfires. | ||||
* | 2008-06-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-06-13 | 2 | -5/+14 |
| | | | | | * rtems/score/m68k.h: There is no point in defining the maximum priorities to 255. priority.h will default it to this. | ||||
* | hris Johns <chrisj@rtems.org> | Chris Johns | 2008-06-11 | 4 | -194/+244 |
| | | | | | | | | * cpu_asm.S: Add Coldfire FPU support. * rtems/score/m68k.h: Change the Coldfire CPU defines to be based on the instruction set. Add Tiny RTEMS support to the small memory model RTEMS processors. * rtems/score/cpu.h: Handle the new Tiny RTEMS support. | ||||
* | 2008-06-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-06-05 | 22 | -1/+227 |
| | | | | | | | | * rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting parameter to indicate that the port uses the Simple Vectored Interrupt model or the Programmable Interrupt Controller Model. The PIC model is implemented primarily in the BSP and it is responsible for all memory allocation. | ||||
* | 2008-06-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-06-04 | 2 | -1/+7 |
| | | | | | | * rtems/score/cpu.h: Use a constant for CPU_STACK_MINIMUM_SIZE so it can be used in cpp expressions. Using sizeof() requires actually compiling the file. | ||||
* | Fix date. | Joel Sherrill | 2008-05-06 | 1 | -1/+1 |
* | Fix typo. | Joel Sherrill | 2008-04-28 | 1 | -5/+0 |
