This CPU port macro was not used. Since the _ISR_Vector_table[] is statically
allocated, CPU ports could initialize this table in _CPU_Initialize() if
necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port
interface.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
Update #3835.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3585.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
The APIC timer is calibrated by running the i8254 PIT for a fraction of a
second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the
APIC counter has ticked. The calibration can be run multiple times (determined
by APIC_TIMER_NUM_CALIBRATIONS) and averaged out.
Updates #2898.
Updates #2898.
Updates #2898.
Updates #2898.
Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment
requirement is defined by the use of Chain_Node (consisting of two
pointers) to manage the free chain of partitions.
It seems that previously the condition
CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node)
was true on all CPU ports. Now, we need an additional check.
Update #3482.
On some architectures/simulators it is difficult to provoke an
exception with misaligned or illegal data loads. Use an illegal
instruction instead.
Update #3433.
This helps to reduce the use of architecture-specific defines throughout
the code base.
The context validation support functions _CPU_Context_validate() and
_CPU_Context_volatile_clobber() are used only by one test program
(spcontext01). Move the function declarations to the CPU port
implementation header file.
This addition allows us to successfully run the sample hello.exe test.
Updates #2898.
Current state:
- Basic context initialization and switching code.
- Stubbed console (empty functions).
- Mostly functional linker script (may need tweaks if we ever want to move
away from the large code model (see: CPU_CFLAGS).
- Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
