* configure.in: Remove.
* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The
bug has been there all the time, but only hits the leon bsp since the
leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
* cpu.c: Added include of <rtems/rtems/cache.h> to eliminate warning.
* cpu_asm.S: Fix for CPUs with FPU revision B or C.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
that switches the sparc from targopts.h to cpuopts.h.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
_Interrupt_Manager_initialization.
converted to automake.
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
egcs source tree handle this correctly. No one should be using
gcc 2.7.2 anymore.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
This is current as of sis 2.6.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
