Update #3285.
Rename SPARC64-specific CPU_Minimum_stack_frame to
SPARC64_Minimum_stack_frame. Rename SPARC64-specific
CPU_MINIMUM_STACK_FRAME_SIZE to SPARC64_MINIMUM_STACK_FRAME_SIZE.
Update #2809.
Update #2559.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
PR 1918/cpukit
* cpu.c: Initialize context with cleared g4 register.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
PR 1561/cpukit
* .cvsignore, ChangeLog, Makefile.am, Makefile.in, README, context.S,
cpu.c, preinstall.am, rtems/asm.h, rtems/score/cpu.h,
rtems/score/sparc64.h, rtems/score/types.h: New files.
