* | sparc64: Rename CPU_Minimum_stack_frame | Sebastian Huber | 2016-11-18 | 1 | -3/+3 |
| | | | | | | | | Rename SPARC64-specific CPU_Minimum_stack_frame to SPARC64_Minimum_stack_frame. Rename SPARC64-specific CPU_MINIMUM_STACK_FRAME_SIZE to SPARC64_MINIMUM_STACK_FRAME_SIZE. Update #2809. | ||||
* | sparc64: fix copyright notices. | Gedare Bloom | 2015-02-23 | 1 | -12/+1 |
| | | | | | The sparc64 port had some incorrect copyright notices affixed to source code files. | ||||
* | sparc64: put each copyright on one line | Gedare Bloom | 2014-12-08 | 1 | -5/+4 |
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 1 | -0/+322 |
PR 1561/cpukit * .cvsignore, ChangeLog, Makefile.am, Makefile.in, README, context.S, cpu.c, preinstall.am, rtems/asm.h, rtems/score/cpu.h, rtems/score/sparc64.h, rtems/score/types.h: New files. |
