* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/powerpc/registers.h: recognize mpc7457 CPU; added definitions
for high bats (#4..7) on 7450 CPUs
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* rtems/score/powerpc.h: Removed warning
* rtems/score/powerpc.h: Add "defined(mpc7400) || defined(mpc7450)
|| defined(mpc7455)" to altivec (gcc-3.2.x compatibility).
CPU_IDLE_TASK_IS_FP, CPU_SOFTWARE_FP): New.
CPU_IDLE_TASK_IS_FP): Remove.
* rtems/new-exceptions/cpu.h (CPU_HARDWARE_FP, CPU_ALL_TASKS_ARE_FP,
* rtems/old-exceptions/cpu.h (CPU_HARDWARE_FP, CPU_ALL_TASKS_ARE_FP,
* rtems/score/cpu.h (CPU_HARDWARE_FP, CPU_ALL_TASKS_ARE_FP,
* rtems/score/cpu.h: Derive CPU_{BIG|LITTLE}_ENDIAN from
__BIG_ENDIAN__.
CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES, CPU_BIG_ENDIAN, CPU_LITTLE_ENDIAN): Add.
CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES, CPU_BIG_ENDIAN, CPU_LITTLE_ENDIAN): Remove
* rtems/score/cpu.h (CPU_PROVIDES_IDLE_THREAD_BODY,
CPU_STACK_GROWS_UP, CPU_STRUCTURE_ALIGNMENT,
* rtems/old-exceptions/cpu.h (CPU_PROVIDES_IDLE_THREAD_BODY,
CPU_LITTLE_ENDIAN): Remove.
* rtems/new-exceptions/cpu.h (CPU_PROVIDES_IDLE_THREAD_BODY,
(rtems_cpu_configuration_get_serial_per_sec,
rtems_cpu_configuration_get_serial_external_clock,
rtems_cpu_configuration_get_serial_xon_xoff,
rtems_cpu_configuration_get_serial_cts_rts,
rtems_cpu_configuration_get_serial_rate,
rtems_cpu_configuration_get_timer_average_overhead,
rtems_cpu_configuration_get_timer_least_valid,
rtems_cpu_configuration_get_timer_internal_clock,
rtems_cpu_configuration_get_clock_speed): New.
* rtems/old-exceptions/cpu.h:
rtems_cpu_configuration_get_clock_speed): Remove.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h
(rtems_cpu_table): Sync defines between {old|new}-exceptions.
* rtems/new-exceptions/cpu.h (Context_Control,
Context_Control_fp, CPU_Interrupt_frame): Remove.
* rtems/old-exceptions/cpu.h (Context_Control,
* rtems/score/cpu.h (Context_Control,
Context_Control_fp, CPU_Interrupt_frame): Add.
CPU_PARTITION_ALIGNMENT, CPU_STACK_ALIGNMENT): Add.
CPU_PARTITION_ALIGNMENT, CPU_STACK_ALIGNMENT): Remove.
* rtems/new-exceptions/cpu.h (CPU_STACK_MINIMUM_SIZE,
CPU_ALIGNMENT, CPU_HEAP_ALIGNMENT,
* rtems/old-exceptions/cpu.h (CPU_STACK_MINIMUM_SIZE,
* rtems/score/cpu.h (CPU_STACK_MINIMUM_SIZE,
* rtems/new-exceptions/cpu.h: Remove CPU_MINIMUM_STACK_FRAME_SIZE.
_CPU_Priority_bits_index): New.
_CPU_Priority_bits_index): Remove.
* rtems/new-exceptions/cpu.h (_CPU_Bitfield_Find_first_bit,
_CPU_Priority_Mask, _CPU_Priority_bits_index): Remove.
* rtems/old-exceptions/cpu.h (_CPU_Bitfield_Find_first_bit,
* rtems/score/cpu.h (_CPU_Bitfield_Find_first_bit,
_CPU_Priority_Mask, _CPU_Priority_bits_index): New.
* rtems/new-exceptions/cpu.h (_CPU_msrs): Remove (Unused).
* rtems/old-exceptions/cpu.h (_CPU_msrs): Remove (Unused).
_CPU_Context_switch, _CPU_Context_restore, _CPU_Context_save_fp, _CPU_Context_restore_fp, _CPU_Fatal_error): New.
_CPU_Context_switch, _CPU_Context_restore, _CPU_Context_save_fp, _CPU_Context_restore_fp, _CPU_Fatal_error): Remove.
* rtems/new-exceptions/cpu.h (_CPU_ISR_install_vector,
_CPU_Initialize, _CPU_Install_interrupt_stack, _CPU_Context_switch,
* rtems/old-exceptions/cpu.h (_CPU_ISR_install_vector,
* rtems/score/cpu.h (_CPU_ISR_install_vector,
_CPU_Context_Initialize_fp): New.
_CPU_Context_Initialize_fp): Remove.
* rtems/old-exceptions/cpu.h (_CPU_Context_Initialize,
_CPU_Context_Restart_self, _CPU_Context_Fp_start,
* rtems/new-exceptions/cpu.h (_CPU_Context_Initialize,
* rtems/score/cpu.h (_CPU_Context_Initialize,
* rtems/old-exceptions/cpu.h (PPC_Get_timebase_register): Remove.
* rtems/powerpc/registers.h (PPC_Get_timebase_register,
PPC_Set_timebase_register): Remove.
* rtems/score/cpu.h (PPC_Get_timebase_register,
PPC_Set_timebase_register): New.
* rtems/powerpc/registers.h (PPC_Set_decrementer,
PPC_Get_decrementer): Remove.
* rtems/old-exceptions/cpu.h (PPC_Set_decrementer): Remove.
* rtems/score/cpu.h (PPC_Set_decrementer, PPC_Get_decrementer): New.
* rtems/old-exceptions/cpu.h (CPU_Get_timebase_low, rtems_bsp_delay,
rtems_bsp_delay_in_bus_cycles): Remove.
* rtems/powerpc/registers.h (CPU_Get_timebase_low, rtems_bsp_delay,
* rtems/score/cpu.h (CPU_Get_timebase_low, rtems_bsp_delay,
rtems_bsp_delay_in_bus_cycles): New.
rtems_cpu_configuration_get_exceptions_in_ram): New.
rtems_cpu_configuration_get_exceptions_in_ram): Remove.
