* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/new-exceptions/cpu.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* rtems/score/cpu.h: Include <rtems/score/types.h> first. Added
contents of <rtems/new-exceptions/cpu.h>.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1588/cpukit
* rtems/powerpc/registers.h: Renamed defines SR0 .. SR15 in
PPC_SR0 .. PPC_SR15.
PR 1573/cpukit
* rtems/new-exceptions/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* cpu.c: Add include of config.h
* score/cpu/powerpc/rtems/score/cpu.h: Added space for non-
volatile AltiVec registers to context struct. Added declaration
for AltiVec-related routines to be implemented by CPU/BSP
support.
* rtems/score/cpu.h: Changed fpscr field to an integer type in
Context_Control_fp. Fixed warnings in PPC_Set_timebase_register().
Changed _CPU_Context_Initialize_fp() to initialize all fields and
avoid floating-point instructions.
* rtems/score/powerpc.h: Removed PPC_INIT_FPSCR define.
Standards (EIS) special purpose register definitions for MMU and L1
cache.
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Eliminate
_CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch
to _CPU_Initialize. Clean up comments.
* rtems/score/cpu.h: Move extern of bsp_clicks_per_usec so it is not
nested inside braces.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Convert to "bool".
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* rtems/new-exceptions/cpu.h: Changed define
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison
between signed and unsigned.
fixed some minors in mpc83xx support
added file for mpc55xx watchdog support
* score/cpu/powerpc/rtems/new-exceptions/cpu.h:
use ppc_interrupt_get_disable_mask() to determine
which bits to set/clear from _CPU_ISR_Set_level().
* score/cpu/powerpc/rtems/powerpc/registers.h:
added ppc_interrupt_get_disable_mask() inline function.
* cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
* posix/src/keycreate.c, posix/src/pthreadequal.c,
rtems/src/semtranslatereturncode.c,
score/cpu/powerpc/rtems/score/powerpc.h,
score/src/threadblockingoperationcancel.c: Fix compilation errors
when --enable-rtems-debug is used.
* rtems/old-exceptions/cpu.h: Remove (Abandoned).
* rtems/score/cpu.h: Remove ref to rtems/old-exceptions/cpu.h.
* Makefile.am: Remove ref to rtems/old-exceptions/cpu.h.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/powerpc/registers.h, rtems/score/cpu.h: Sweep to make sure grep
for COPYRIGHT passes.
* rtems/powerpc/registers.h: added definitions for MSR_CE,
MSR_DE (bookE).
* rtems/old-exceptions/cpu.h: Remove extra ifndef.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/score/cpu.h: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* rtems/score/cpu.h: Added comment that GDB patch sim/2376
is needed for reading the time-base with the new (more
portable) method.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Moved most of
the remaining CPU Table fields to the Configuration Table. This
included pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* rtems/score/cpu.h: Wonderful bookE doesn't have mftb/mftbu;
( CPU_Get_timebase_low() ) they only define the TBRU/TBRL SPRs
so we use these. Should work on all CPUs.
rtems/score/cpu.h: Eliminate PowerPC specific elements from the CPU
Table. They have been replaced with variables named bsp_XXX as
needed.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* rtems/score/powerpc.h: Added a '__ppc_generic' CPU variant.
The goal would be making cpukit and hopefully libcpu work
for all (or at least most) CPUs/BSPs with -D__ppc_generic so
that eventually all tests [#if defined(<cpu_flavor>)] for CPU
flavors can be eliminated.
* rtems/powerpc/registers.h: Added SPR definitions for BookE
DECAR, TCR, TSR.
many different versions of new exception handling code to shared sources.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
Use Context_Control_fp* instead of void* for fp_contexts.
Eliminate evil casts.
