The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Rename _Internal_error_Occurred() into _Terminate().
http://www.google-melange.com/gci/task/view/google/gci2012/7983217
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for
_CPU_ISR_install_vector().
