path: root/cpukit/score/cpu/powerpc/headers.am (unfollow)
2021-09-21build: Remove old build systemSebastian Huber1-9/+0
Close #3250. Close #4081.
2018-10-10build: Include header.am in cpukit/Makefile.amSebastian Huber1-20/+8
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets rid of all subtree Makefile.am and the sudirs hack.
2018-03-13Add PowerPC paravirtualization supportJoel Sherrill1-0/+1
Cannot read or write MSR when executing in user mode. This is used when RTEMS_PARAVIRT is defined. Provide alternate methods to disable/enable interrupts Closes #3306.
2018-03-12powerpc/include/rtems/score/types.h: Eliminate this fileJoel Sherrill1-1/+0
Updates #3327.
2018-01-25Remove make preinstallChris Johns1-0/+21
