* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -5/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -5/+0 |
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 3 | -31/+8 |
| | | | | | | * configure.ac: Remove (Merged into$(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -8/+13 |
| | | | | * Makefile.am: Install asm.h to $(includedir)/rtems. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 4 | -36/+41 |
| | | | | | * cpu.c, cpu_asm.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+5 |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | ||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -2/+8 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+9 |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 |
| | | | | * configure.ac: Requires automake >= 1.8.1. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 |
| | | | | * Makefile.am: Include compile.am, again. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -11/+14 |
| | | | | * Makefile.am: Convert to using automake compilation rules. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -4/+6 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -12/+18 |
| | | | | * Makefile.am:Restore further parts having been lost. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+53 |
| | | | | * Makefile.am: Restore file having been broken in last commit. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -60/+6 |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -12/+22 |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -20/+32 |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -7/+5 |
| | | | | | * rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 7 | -6/+11 |
| | | | | | * cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/or32.h, rtems/score/types.h: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 3 | -6/+9 |
| | | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 |
| | | | | * configure.ac: Fix package name. | ||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-09-14 Ivan Guzvinec <ivang@opencores.org> | Joel Sherrill | 2002-09-14 | 2 | -0/+16 |
| | | | | | * rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL since it is not used. | ||||
* | 2002-08-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-06 | 4 | -4/+9 |
| | | | | | * asm.h, rtems/score/cpu.h: Correct items that have changed since RTEMS version or32 port was based upon. | ||||
* | 2002-08-05 Chris Ziomkowski <chris@asics.ws> | Joel Sherrill | 2002-08-05 | 8 | -297/+648 |
| | | | | | * asm.h, cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/or32.h, rtems/score/types.h: Merged from OpenCores CVS repository. | ||||
* | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-26 | 2 | -7/+9 |
| | | | | * Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | ||||
* | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-22 | 2 | -1/+5 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-05 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP(../../../..). | ||||
* | 2002-07-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-03 | 2 | -6/+6 |
| | | | | | * rtems.c: Remove. * Makefile.am: Reflect changes above. | ||||
* | 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-01 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_PROJECT_ROOT. | ||||
* | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-27 | 2 | -0/+5 |
| | | | | * configure.ac: Add RTEMS_PROG_CCAS | ||||
* | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-27 | 2 | -1/+7 |
| | | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB. | ||||
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 2 | -5/+10 |
| | | | | | * Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal. | ||||
* | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-03 | 3 | -2/+9 |
| | | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/or32types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-02-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-27 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Fix conditional to match current GCC. | ||||
* | 2001-02-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-05 | 1 | -0/+4 |
| | | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again. | ||||
* | 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-30 | 3 | -19/+35 |
| | | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above. | ||||
* | 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-12-19 | 2 | -3/+7 |
| | | | | * Makefile.am: Add multilib support. | ||||
* | 2001-11-28 Joel Sherrill <joel@OARcorp.com>, | Joel Sherrill | 2001-11-28 | 2 | -0/+14 |
| | | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 3 | -0/+39 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. |
