Close #2232.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
Rename Priority_bit_map_Control in Priority_bit_map_Word.
Rename _Internal_error_Occurred() into _Terminate().
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add proper license and copyright.
Add CPU port specific per-CPU control.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
architectures. SMP atomic port will be later.
This reflects what is currently happening. Define CPU_Interrupt_frame
type to void to prevent accidental usage.
Add _Nios2_Count_trailing_zeros(). They are currently more efficient
than the corresponding GCC builtins.
This fix is critical. The previous implementation leads to system
corruption.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013205
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
for details.
Add
o _Nios2_MPU_Get_region_descriptor(), and
o _Nios2_MPU_Set_region_registers().
corruption.
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* nios2-context-switch.S: Use small-data area access for
_Per_CPU_Information fields.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* nios2-eic-il-low-level.S, nios2-eic-rsie-low-level.S: New files.
* rtems/score/cpu.h, rtems/score/nios2-utility.h,
nios2-thread-dispatch-disabled.c, nios2-context-switch.S: Added
support for thread stack protection via the MPU.
* rtems/score/cpu.h: Request cache alignment and small data area in
CPU_STRUCTURE_ALIGNMENT.
* nios2-thread-dispatch-disabled.c: Use offsetof() instead of
RTEMS_offsetof().
* rtems/score/nios2-utility.h, nios2-isr-set-level.c,
nios2-isr-get-level.c: Renamed functions.
* rtems/score/nios2-utility.h: Use the same values for defines used by
Altera HAL.
* rtems/score/nios2-utility.h: Avoid redefines with Altera HAL.
Declare _Nios2_ISR_Set_level().
* nios2-context-initialize.c: Use _Nios2_ISR_Set_level().
* nios2-isr-set-level.c: Define _Nios2_ISR_Set_level().
