for details.
Add
o _Nios2_MPU_Get_region_descriptor(), and
o _Nios2_MPU_Set_region_registers().
This fix is critical. The previous implementation leads to system
corruption.
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* nios2-context-switch.S: Use small-data area access for
_Per_CPU_Information fields.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* nios2-eic-il-low-level.S, nios2-eic-rsie-low-level.S: New files.
* rtems/score/cpu.h, rtems/score/nios2-utility.h,
nios2-thread-dispatch-disabled.c, nios2-context-switch.S: Added
support for thread stack protection via the MPU.
* rtems/score/cpu.h: Request cache alignment and small data area in
CPU_STRUCTURE_ALIGNMENT.
* nios2-thread-dispatch-disabled.c: Use offsetof() instead of
RTEMS_offsetof().
* rtems/score/nios2-utility.h, nios2-isr-set-level.c,
nios2-isr-get-level.c: Renamed functions.
* rtems/score/nios2-utility.h: Use the same values for defines used by
Altera HAL.
* rtems/score/nios2-utility.h: Avoid redefines with Altera HAL.
Declare _Nios2_ISR_Set_level().
* nios2-context-initialize.c: Use _Nios2_ISR_Set_level().
* nios2-isr-set-level.c: Define _Nios2_ISR_Set_level().
* cpu.c, cpu_asm.S: Removed files.
* nios2-context-initialize.c, nios2-context-switch.S,
nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c,
nios2-isr-get-level.c, nios2-isr-install-raw-handler.c,
nios2-isr-install-vector.c, nios2-isr-is-in-progress.c,
nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c,
rtems/score/nios2-utility.h: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* irq.c: Update due to API changes.
* rtems/score/cpu.h: New functions _CPU_Initialize_vectors(),
_CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros).
Support for external interrupt controller (EIC). Documentation
changes.
* cpu.c: Fix the ISR get level for the IIC. Make
_CPU_Context_Initialize a function rather than inlined.
* cpu_asm.S: Do not enable interrupt on return, rather resume the
state on entry to the ISR.
* irq.c, nios2/nios2-iic-low-level.S: Change the ISR handler so
the ipending decoding is in C and within the interrupt
context. This is usable with the Altera HAL directly.
* rtems/score/cpu.h: Add ienable and ipending interfaces. Add some
comments. Remove _CPU_Context_Initialize.
* rtems/score/cpu.h: Clear the vector table for simple vectored
interrupts.
* irq.c: Add support for using the IIC with the Altera HAL.
* rtems/score/cpu.h: Removed superfluous comments. Format. Include
by assembler support. Removed superfluous floating-point support.
Stack alignment is now 4.
* rtems/score/cpu.h, cpu.c: Removed superfluous functions.
* nios2-iic-low-level.S: New file.
* cpu_asm.S: Moved low-level interrupt handling into new file.
* Makefile.am: Reflect change from above.
* cpu_asm.S, rtems/score/cpu.h: There is no need to save the global
pointer (gp) in the thread register context since it is a system wide
constant and set-up with the C runtime environment.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* Makefile.am: Reformat.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* irq.c:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1599/cpukit
* irq.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary
to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* irq.c, rtems/score/cpu.h: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* cpu.c, cpu_asm.S, irq.c: Add include of config.h
* cpu_asm.S: Eliminate extern of unused variables.
* cpu.c: Remove stray semi-colon.
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* rtems/score/cpu.h: Remove extraneous spaces.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* irq.c: Sweep to make sure grep for COPYRIGHT passes.
