* cpu.c: Fix the ISR get level for the IIC. Make
_CPU_Context_Initialize a function rather than inlined.
* cpu_asm.S: Do not enable interrupt on return, rather resume the
state on entry to the ISR.
* irq.c, nios2/nios2-iic-low-level.S: Change the ISR handler so
the ipending decoding is in C and within the interrupt
context. This is usable with the Altera HAL directly.
* rtems/score/cpu.h: Add ienable and ipending interfaces. Add some
comments. Remove _CPU_Context_Initialize.
* nios2-iic-low-level.S: New file.
* cpu_asm.S: Moved low-level interrupt handling into new file.
* Makefile.am: Reflect change from above.
