* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e.
* cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h:
Replace M68K_COLDFIRE_ARCH with __mcoldfire__.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
Use Context_Control_fp* instead of void* for fp_contexts.
* rtems/score/types.h: Remove unsigned64, signed64.
* cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector
bits are used when calculating the exception vector.
operations. The "memory" barrier will move the the generic interrupt
enable/disable/flash macros.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
PR 803/patch
* rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR.
* rtems/score/cpu.h, rtems/score/m68k.h: Change declaration of _VBR.
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* cpu.c: Remove warning.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
* rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h,
rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup.
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
PR rtems/752
rtems/m68k/sim.h: New (relocated from .).
* m68302.h, m68360.h, qsm.h, sim.h: Remove.
* asm.h, rtems/score/cpu.h, rtems/score/m68k.h, rtems/score/types.h:
New header guards.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/m68k.h: *_swap_u32( uint32_t ).
* rtems/score/m68k.h: *_swap_u16( uint16_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
