* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* rtems/score/types.h: Remove unsigned64, signed64.
operations. The "memory" barrier will move the the generic interrupt
enable/disable/flash macros.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
PR 803/patch
* rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR.
* rtems/score/cpu.h, rtems/score/m68k.h: Change declaration of _VBR.
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h,
rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/m68k.h: *_swap_u32( uint32_t ).
* rtems/score/m68k.h: *_swap_u16( uint16_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/m68k.h: Add include of <stdint.h> for uint32_t used by
endian swapping routines.
* cpu.c, m68302.h, rtems/score/cpu.h, rtems/score/m68k.h: Convert to
using c99 fixed size types.
PR 561/rtems
* asm.h: Add CONCAT0, EVAL. Let SYM and REG use CONCAT0 and EVAL.
* qsm.h, sim.h: Remove efi68k and efi332 references as they are no
longer in the tree.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h,
rtems/score/types.h: URL for license changed.
* m68360.h: Correct the order of fields in the ethernet structure
to account for the typo in MC68360UM (page 7-248).
* cpu_asm.S: Per PR267, the _ISR_Handler() function never was modifying
_ISR_Nest_level, and _Watchdog_Insert() requires this variable
to be modified to determine if an interrupt may have modified
the watchdog chain. Prior to modifying _ISR_Handler(), I had
a test that would fail if _ISR_Flash was not commented out in
_Watchdog_Insert(). After this modification was made, my test
ran flawlessly.
* rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP
since it is now multilib'ed.
* include/rtems/score/ispsh7750.h, score/ispsh7750.c: Account for
name change.
* rtems/score/m68k.h: m68k_swap_u32 fix typo.
* rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32):
Generic implementation of endian swap primitives added for Coldfire
family.
This was tracked as PR91.
* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
* rtems/score/cpu.h: define CPU_Exception_frame for rdbg.
* m68302.h: Make buffer pointer in m302_SCC_bd volatile.
* sim.h: These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* BSP/start/start.c: Must be modified to support above.
* BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
significant things:
and PowerPC
same code base.
