Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Add CPU port define for the interrupt stack alignment. The alignment
should take the stack ABI and the cache line size into account.
Update #3459.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
The following code
void f(void)
register int i;
gives a warning with GCC and -std=c++17
test.cc: In function ‘void f()’:
test.cc:3:15: warning: ISO C++1z does not allow ‘register’ storage class
specifier [-Wregister]
register int i;
and clang with -std=c++14
test.cc:3:3: warning: 'register' storage class specifier is deprecated
and incompatible with C++1z [-Wdeprecated-register]
register int i;
1 warning generated.
Remove the use of the register keyword at least in the public header
files for C++ compatibility.
Close #3397.
Updates #3327.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Since the FP area pointer is passed by reference in
_CPU_Context_Initialize_fp() the optional FP area adjustment via
_CPU_Context_Fp_start() is superfluous. It is also wrong with respect
to memory management, e.g. pointer passed to _Workspace_Free() may be
not the one returned by _Workspace_Allocate().
Close #1400.
Use de-facto standard BYTE_ORDER instead.
Close #2803.
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates
a level parameter and returns a boolean value.
Update #2811.
Update #2808.
Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to
<rtems/score/cpuimpl.h> to hide it from <rtems.h>.
The thread dispatch inline option is no longer used.
The aim of this file is to encapsulate CPU port implementation details.
This helps to hide implementation details from <rtems.h> which
indirectly includes <rtems/score/cpu.h>.
Only use CPU_Per_CPU_control if it contains at least one filed. In GNU
C empty structures have a size of zero. In C++ structures have a
non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero,
then this structure is not used anymore.
The priority bit map can deal with a maximum of 256 priority values
ranging from 0 to 255. Consistently use an unsigned int for
computation, due to the usual integer promotion rules.
Make Priority_bit_map_Word definition architecture-independent and
define it to uint16_t. This was already the case for all architectures
except PowerPC. Adjust the PowerPC bitmap support accordingly.
Rename __log2table into _Bitfield_Leading_zeros since it acually returns
the count of leading zeros of an 8-bit integer. The value for zero is a
bit odd. Provide it unconditionally.
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
This is a preparation to remove the Giant lock.
Update #2555.
Maximum number of processors of all systems supported by this CPU port.
Update #2559.
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The
actual processor may use no cache or a smaller cache line size.
Update #2271.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
Rename Priority_bit_map_Control in Priority_bit_map_Word.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add proper license and copyright.
Add CPU port specific per-CPU control.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
architectures. SMP atomic port will be later.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
for details.
