* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | This is the initial addition of the port of RTEMS to the | Joel Sherrill | 2000-06-29 | 1 | -0/+31 |
Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity. |
