* | 2006-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-16 | 2 | -6/+11 |
| | | | | | | * rtems/score/cpu.h: Part of a large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate | Ralf Corsepius | 2006-01-13 | 1 | -0/+2 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 2 | -2/+6 |
| | | | | * rtems/score/types.h: Eliminate unsigned16, unsigned32. | ||||
* | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -4/+6 |
| | | | | | * rtems/asm.h: Remove private version of CONCAT macros. Include <rtems/concat.h> instead. | ||||
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-19 | 2 | -58/+62 |
| | | | | * rtems/score/cpu.h: Remove traces from NO_CPU. | ||||
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 3 | -35/+52 |
| | | | | | * Makefile.am: Split out preinstallation rules. * preinstall.am: New (Split out from Makefile.am). | ||||
* | Header guards cleanup. | Ralf Corsepius | 2005-02-04 | 1 | -1/+1 |
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 3 | -102/+9 |
| | | | | | | | PR 754/rtems * rtems/asm.h: New (relocated from .). * asm.h: Remove (moved to rtems/asm.h). * Makefile.am: Reflect changes above. | ||||
* | New header guard. | Ralf Corsepius | 2005-01-28 | 6 | -12/+12 |
* | 2004-01-28 Ralf Corsepius <ralf.corsepiu@rtems.org> | Ralf Corsepius | 2005-01-28 | 1 | -0/+5 |
| | | | | | * asm.h, rtems/score/avr.h, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/types.h: New header guards. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -8/+7 |
| | | | | | * rtems/score/types.h: Remove signed8, signed16, signed32, unsigned8, unsigned16, unsigned32. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -2/+6 |
| | | | | * rtems/score/cpu.h: *_swap_u32( uint32_t ). | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-01 | 2 | -9/+7 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-11-21 | 2 | -2/+0 |
* | 2004-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 3 | -6/+14 |
| | | | | * asm.h: Add doxygen preamble. | ||||
* | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-02 | 5 | -8/+26 |
| | | | | | | | * rtems/score/avr.h: Add doxygen preamble. * rtems/score/cpu.h: Add doxygen preamble. * rtems/score/cpu_asm.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | ||||
* | 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-01 | 2 | -12/+19 |
| | | | | | * rtems/score/types.h: s/no_cpu/avr/g. Use POSIX types from rtems/stdint.h. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -4/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | New. | Ralf Corsepius | 2004-09-24 | 12 | -0/+1994 |
