* cpu.c, cpu_asm.S, rtems/score/cpu.h: Remove /*PAGE markers which were
* cpu.c, avr/interrupt.h, avr/power.h, rtems/score/cpu.h:
* cpu.c, cpu_asm.S: Add include of config.h
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Fix bug in
_CPU_Context_Initialize.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Context switch now works well
enough to run ticker to completion with the simulator clock idle
task. But if you comment out the printk's in _CPU_Context_Initialize,
it hangs. This remains to be investigated.
* cpu.c, cpu_asm.S: Unsuccessful attempt to fix.
*cpu_asm.S: implemented _CPU_Context_Restore by adding tags to
restore section of context switch.
Fixed bug in _CPU_Context_Switch. The wrong registers were being
used for pointer to running task Context_Control struct.
* cpu.c: Implemented _CPU_Context_Initialize as a C function instead
of a macro. It works with limited functionality. Implemented
_CPU_Thread_Idle_body to use sleep instruction.
* Makefile.am: Changed cpu_asm.c -> cpu_asm.S
* cpu_asm.S: renamed from cpu_asm.c and implemented functions is asm
* rtems/asm.h: Appended "macros.inc" to the end of "asm.h"
* rtems/score/cpu.h:
+ Included "avr/io.h".
+ Added use 16 bit object definition.
+ Modified Context_Control struct to relect the registers
that need to be saved.
+ Implemented _CPU_ISR_Disable, _CPU_ISR_Enable, and _CPU_ISR_Flash.
Added function definitions for _CPU_Context_Initialize and
_CPU_Push.
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* cpu.c, cpu_asm.c: Remove warnings -- even if code is just temporary.
* cpu.c, cpu_asm.c: Add debug printk() calls until the BSP/port can
initialize and shutdown completely cleanly. When this works,
implement context switch. Testing on avrtest and simulavr.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
