* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -4/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | 2004-08-19 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2004-08-20 | 2 | -1/+7 |
| | | | | | | PR 671/bsps * rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param was always ignored. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -7/+0 |
* | 2004-04-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-04-09 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Fix typo. | ||||
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 3 | -31/+8 |
| | | | | | | * configure.ac: Remove (Merged into $(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -8/+13 |
| | | | | * Makefile.am: Install asm.h to $(includedir)/rtems. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
| | | | | * cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 3 | -52/+56 |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+5 |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | ||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -2/+8 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+9 |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 |
| | | | | * configure.ac: Requires automake >= 1.8.1. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 |
| | | | | * Makefile.am: Include compile.am, again. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -14/+14 |
| | | | | * Makefile.am: Convert to using automake compilation rules. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -4/+6 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -12/+18 |
| | | | | * Makefile.am:Restore further parts having been lost. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+56 |
| | | | | * Makefile.am: Restore file having been broken in last commit. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -63/+6 |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -12/+26 |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -20/+32 |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -7/+5 |
| | | | | | * rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 9 | -8/+13 |
| | | | | | * asm.h, cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/types.h: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-04-17 | 2 | -1/+5 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | Fix CVS-Ids | Ralf Corsepius | 2003-03-11 | 3 | -3/+3 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-04 | 3 | -9/+20 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-28 | 2 | -0/+10 |
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 3 | -8/+11 |
| | | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 |
| | | | | * configure.ac: Fix package name. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 2 | -1/+5 |
| | | | | * cpu.c: Removed warning. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -2/+5 |
| | | | | * cpu.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Removed warning. | ||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-10-04 | 2 | -15/+19 |
| | | | | * rtems/score/cpu.h: Fix u16 and u32 swap routines. | ||||
* | 2002-08-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-05 | 3 | -2/+6 |
| | | | | * rtems/score/cpu.h, rtems/score/types.h: Updated to fix some typos. | ||||
* | 2002-07-30 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-07-30 | 7 | -320/+325 |
| | | | | | | | | | * cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/types.h: ARM port works well enough to run all sptests, tmtests, and ttcp. In addition to general cleanup, there has been considerable optimization to interrupt disable/enable, endian swapping, and context switching. | ||||
* | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-26 | 2 | -7/+9 |
| | | | | * Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | ||||
* | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-22 | 2 | -2/+10 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-07-17 | 7 | -207/+324 |
| | | | | | | | | | | | * rtems/score/cpu_asm.h: Enhanced to include register offsets. * Makefile.am: Install rtems/score/cpu_asm.h. * cpu.c: Significantly enhanced including the implementation of _CPU_ISR_Get_level. * cpu_asm.S: Improved behavior of context switch and interrupt dispatching. * rtems/score/arm.h: Improved the CPU model name determination. * rtems/score/cpu.h: Improved interrupt disable/enable functions. | ||||
* | 2002-07-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-05 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Filled in something that was marked XXX. | ||||
* | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-05 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP(../../../..). | ||||
* | 2002-07-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-03 | 2 | -5/+5 |
| | | | | | * rtems.c: Remove. * Makefile.am: Reflect changes above. |
