Update #3706.
Update #3706.
Update #3706.
The register definition for the CP15 PMCR (performance monitor control
register) has the bits for X (export enable) and D (clock divider
enable) backwards. Correct them according to ARMv7-A/R Architecture
Reference Manual, Rev C, Section B4.1.117.
Consequences: On an implementation that starts off with D set at reset,
the clock divider will not be disabled by using RTEMS' definition of the
D bit.
Tested by using the counter on Xilinx Zynq 7020 to measure some atomic
accesses and cache flushing operations.
The system register in use for retrieval of the virtual timer value was
mistakenly copied from the physical timer value retrieval function.
Virtual timer value retrieval should use the same system register as the
virtual timer value setter.
Close #3699.
- Fix the handling of pending objects.
- Add a constructor flags in objects to track then being called.
Closes #2921
Update #3585.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment
requirement is defined by the use of Chain_Node (consisting of two
pointers) to manage the free chain of partitions.
It seems that previously the condition
CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node)
was true on all CPU ports. Now, we need an additional check.
Update #3482.
On some architectures/simulators it is difficult to provoke an
exception with misaligned or illegal data loads. Use an illegal
instruction instead.
Update #3433.
This helps to reduce the use of architecture-specific defines throughout
the code base.
The context validation support functions _CPU_Context_validate() and
_CPU_Context_volatile_clobber() are used only by one test program
(spcontext01). Move the function declarations to the CPU port
implementation header file.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Add CPU port define for the interrupt stack alignment. The alignment
should take the stack ABI and the cache line size into account.
Update #3459.
Use the standard ARMv7-M systick module for the ARMv7-M CPU counter
instead of DWT counter since the DWT counter is affected by power saving
states.
Use an inline function for _CPU_Counter_difference() for all ARM BSPs.
Update #3456.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Closes #3305.
Updates #3327.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3093.
Update #3093.
Right after a "msr basepri_max, %[basepri]" instruction an interrupt
service may still take place (observed at least on Cortex-M7). However,
pendable service calls that are activated during this interrupt service
may be delayed until interrupts are enable again. The
_ARMV7M_Pendable_service_call() did not check that a thread dispatch is
allowed. Move this test from _ARMV7M_Interrupt_service_leave() to
_ARMV7M_Pendable_service_call().
Update #3060.
There is no need to save the thread pointer in _CPU_Context_switch()
since it is a thread invariant. It is initialized once in
_CPU_Context_Initialize().
Update #2751.
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the
interrupts are always enabled during a context switch even after
interrupt processing (see #2751). Remove the CPSR from the context
control since it contains only volatile bits.
Close #2954.
Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4.
It is necessary to enable the DWT using a special initialization
sequence before the CYCCNT can be enabled. See for example the
RESET_CYCLE_COUNTER in libbsp/arm/atsam/utils/utility.h.
Note that this problem only occurs if no debugger is connected. A
debugger most likely already enables the necessary module.
Since the FP area pointer is passed by reference in
_CPU_Context_Initialize_fp() the optional FP area adjustment via
_CPU_Context_Fp_start() is superfluous. It is also wrong with respect
to memory management, e.g. pointer passed to _Workspace_Free() may be
not the one returned by _Workspace_Allocate().
Close #1400.
Use de-facto standard BYTE_ORDER instead.
Close #2803.
Update #2751.
Update #2811.
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
Use the right register to determine if a thread dispatch is allowed and
necessary.
Update #2751.
We cannot use the MRS or MSR instructions in Thumb-1 mode. Stay in ARM
mode for the Thumb-1 targets during interrupt low-level processing.
Update #2751.
Close #2816.
In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates
a level parameter and returns a boolean value.
Update #2811.
Update #2751.
Move profiling code closer to bsp_interrupt_disable() to allow re-use of
r9 later.
Use a processor-specific interrupt frame during context switches in case
the executing thread is longer executes on the processor and the heir
thread is about to start execution. During this period we must not use
a thread stack for interrupt processing.
Update #2809.
Update #2809.
Update #2808.
