* | 2011-04-15 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-04-15 | 2 | -1/+8 |
| | | | | | | PR 1780/cpukit * rtems/score/cpu.h: Lower alignment requirements for CPU_PARTITION_ALIGNMENT according to AAPCS. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 3 | -9/+14 |
| | | | | | * cpu.c, rtems/score/cpu.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2010-11-23 Gedare Bloom <giddyup44@yahoo.com> | Sebastian Huber | 2010-11-23 | 2 | -1/+14 |
| | | | | | PR 1719/cpukit * arm_exc_abort.S: Avoid "bx" instruction to support ARMv4 and below. | ||||
* | 2010-11-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-22 | 2 | -3/+9 |
| | | | | * rtems/score/cpu.h: Set alignment requirements according to AAPCS. | ||||
* | 2010-07-29 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-29 | 2 | -1/+12 |
| | | | | | | | | | | | PR 1635/cpukit * rtems/score/types.h: Refactoring of priority handling, to isolate the bitmap implementation of priorities in the supercore so that priority management is a little more modular. This change is in anticipation of scheduler implementations that can select how they manage tracking priority levels / finding the highest priority ready task. Note that most of the changes here are simple renaming, to clarify the use of the bitmap-based priority management. | ||||
* | 2010-07-16 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-16 | 3 | -23/+8 |
| | | | | | * rtems/score/cpu.h: Include <rtems/score/types.h> first. * rtems/score/types.h: Use <rtems/score/basedefs.h> header file. | ||||
* | 2010-07-06 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-06 | 2 | -2/+5 |
| | | | | | * rtems/score/cpu.h: Removed CPU_ENABLE_C_ISR_DISPATCH_IMPLEMENTATION define. | ||||
* | 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 2 | -15/+11 |
| | | | | | | | PR 1573/cpukit * arm_exc_interrupt.S: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 2 | -1/+6 |
| | | | | | * rtems/score/arm.h: Make it a warning not error that the FPU multilib is not supported yet. | ||||
* | add/adapt documentation | Thomas Doerfler | 2010-04-08 | 12 | -69/+182 |
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 2 | -1/+5 |
| | | | | * arm_exc_abort.S: Fix warnings about TRUE/FALSE not defined. | ||||
* | 2010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-27 | 7 | -0/+29 |
| | | | | | * arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S, cpu.c, cpu_asm.S: Add include of config.h | ||||
* | add support for lpc32xx | Thomas Doerfler | 2010-01-12 | 7 | -94/+272 |
* | add support for ARM11, reimplement nested interrupts | Thomas Doerfler | 2009-12-15 | 3 | -149/+127 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 6 | -25/+25 |
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+7 |
| | | | | * rtems/score/arm.h: Recognize ARMv7A. | ||||
| | | | | * rtems/score/arm.h: Recognize ARMv6J as needed by arm1136 variants. | ||||
* | * rtems/score/cpu.h: Fix for inline asm in _CPU_Fatal_halt(). | Thomas Doerfler | 2009-09-18 | 5 | -43/+23 |
| | | | | | * rtems/asm.h: Added macro to define ARM functions. * cpu_asm.S, arm_exc_handler_low.S: Use macro from above. | ||||
* | 2009-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-19 | 2 | -1/+7 |
| | | | | | * rtems/score/cpu.h: Mark _CPU_Context_restore() as noreturn so the compiler will not generate code thinking it returns. | ||||
* | adding lpc24xx BSP parts | Thomas Doerfler | 2009-07-17 | 3 | -0/+520 |
* | removing unneeded files | Thomas Doerfler | 2009-07-17 | 3 | -199/+0 |
* | exception handler maintenance | Thomas Doerfler | 2009-07-17 | 6 | -1037/+350 |
* | 2009-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-05 | 2 | -4/+8 |
| | | | | * rtems/score/cpu.h: Remove warnings. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 3 | -9/+10 |
| | | | | | | * cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | Fix typo. | Ralf Corsepius | 2008-12-07 | 1 | -1/+1 |
* | 2008-09-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-11 | 2 | -5/+12 |
| | | | | | * rtems/score/types.h: Do not define boolean, single_precision, double_precision unless RTEMS_DEPRECATED_TYPES is given. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -4/+8 |
| | | | | * cpu.c: Remove extraneous spaces. | ||||
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+5 |
| | | | | | * Makefile.am: Merge thumb/Makefile.am. * thumb/Makefile.am: Remove (superfluous). | ||||
* | Merge thumb/Makefile.am. | Ralf Corsepius | 2008-09-07 | 1 | -3/+2 |
* | Remove (superfluous). | Ralf Corsepius | 2008-09-07 | 1 | -14/+0 |
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -2/+2 |
* | 2008-08-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-21 | 1 | -0/+5 |
| | | | | | * rtems/score/types.h: Include stdbool.h. Use bool as base-type for boolean. | ||||
* | Include stdbool.h. Use bool as base-type for boolean. | Ralf Corsepius | 2008-08-21 | 1 | -1/+2 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-19 | 1 | -3/+3 |
* | 2008-08-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-18 | 3 | -2/+6 |
| | | | | * cpu.c, rtems/score/cpu.h: Add void. | ||||
* | 2008-04-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-04-18 | 2 | -2/+11 |
| | | | | * cpu.c: Add comment. | ||||
* | 2008-04-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-04-17 | 2 | -1/+8 |
| | | | | | * cpu.c: Add arm_cpu_mode so ARM BSP can overrid default value for cpsr. | ||||
* | 2007-12-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-12-17 | 2 | -0/+7 |
| | | | | * rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility. | ||||
* | 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-17 | 2 | -3/+5 |
| | | | | * rtems/score/cpu_asm.h: Sweep to make sure grep for COPYRIGHT passes. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 2 | -89/+99 |
| | | | | * thumb_isr.c: Style. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 2 | -9/+25 |
| | | | | | * rtems/score/cpu.h: Temporarily use C implementation of swap u32 for thumb mode. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 3 | -13/+6 |
| | | | | | | * cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-03 | 2 | -24/+9 |
| | | | | | | | | | * rtems/score/cpu.h: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | ||||
* | 2007-11-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-27 | 2 | -0/+9 |
| | | | | | * rtems/score/cpu.h: Do not inline _Thread_Enable_dispatch for Thumb to save space. | ||||
* | 2007-11-26 Ray Xu <rayx.cn@gmail.com> | Joel Sherrill | 2007-11-26 | 4 | -1/+13 |
| | | | | | * cpu.c, score/cpu.h: Fix headers. Remove extra inline definition. * cpu_asm.S: Note origin of Thumb support. | ||||
* | 2007-11-26 Ray Xu <rayx.cn@gmail.com> | Joel Sherrill | 2007-11-26 | 2 | -27/+14 |
| | | | | | * thumb_isr.c: Remove extra debug information, Change function definition. | ||||
* | 2007-11-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-06 | 2 | -0/+5 |
| | | | | * cpu.c: Fix headers. | ||||
* | 2007-11-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-06 | 2 | -2/+13 |
| | | | | * thumb_isr.c: Fix headers. |
