path: root/cpukit/posix/src/mutexinit.c (follow)
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* score: Fix legacy RTEMS_STATIC_ASSERT()Sebastian Huber2018-10-051-1/+1
| | | | | | | | | In standard C pointer operands are not allowed in integer constant expressions. Avoid a static assertion based on an array typedef since this could lead to warnings ("variably modified 'x' at file scope" and "typedef 'x' locally defined but not used"); This implementation requires unique messages.
* posix: Include missing <limits.h>Sebastian Huber2017-10-111-0/+2
* posix: Implement self-contained POSIX mutexSebastian Huber2017-10-051-22/+61
| | | | | | | | POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
* posix: Allow PTHREAD_PROCESS_SHARED for mutexesSebastian Huber2017-09-151-7/+3
| | | | Close #3125.
* posix/src/mutexinit.c: Reorder to make priority a scoped variableJoel Sherrill2017-04-271-28/+24
* posix/src/mutexinit.c: Reorder to make priority a scoped variableJoel Sherrill2017-04-261-22/+19
* posix/src/mutexinit.c: Fix used before initialized warningJoel Sherrill2017-04-251-0/+3
* score: Introduce Thread_Scheduler_control::homeSebastian Huber2016-11-021-1/+1
| | | | | | | | Replace Thread_Scheduler_control::control and Thread_Scheduler_control::own_control with new Thread_Scheduler_control::home. Update #2556.
* score: Introduce map priority scheduler operationSebastian Huber2016-06-221-7/+2
| | | | | | | | | | | Introduce map/unmap priority scheduler operations to map thread priority values from/to the user domain to/from the scheduler domain. Use the map priority operation to validate the thread priority. The EDF schedulers use this new operation to distinguish between normal priorities and priorities obtain through a job release. Update #2173. Update #2556.
* posix: Generalize _POSIX_Priority_To_core()Sebastian Huber2016-06-221-4/+4
| | | | Move POSIX API priority validation into _POSIX_Priority_To_core().
* posix: Make POSIX API aware of scheduler instancesSebastian Huber2016-06-221-2/+3
* posix: _POSIX_Mutex_Default_attributesSebastian Huber2016-06-221-2/+12
| | | | | | Make _POSIX_Mutex_Default_attributes constant and independent of the scheduler instance. Use INT_MAX to indicate the default ceiling priority.
* posix: pthread_mutexattr_setprioceiling()Sebastian Huber2016-06-221-8/+11
| | | | | | | Accept all priority values in pthread_mutexattr_setprioceiling(). This is in line with POSIX and FreeBSD. The priority is validated in pthread_mutex_init(). Validate the priority only for priority ceiling mutexes.
* score: Rework CORE inherit priority mutexSebastian Huber2016-05-301-27/+16
| | | | | Provide dedicated seize and surrender methods for inherit priority mutexes. This eliminates CORE_mutex_Attributes.
* score: Rework CORE priority ceiling mutexSebastian Huber2016-05-301-10/+6
| | | | | Rework seize and surrender methods to use CORE_ceiling_mutex_Control. This eliminates CORE_mutex_Disciplines.
* score: Add CORE mutex variantsSebastian Huber2016-05-301-22/+41
| | | | | | | | Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid the run-time evaluation of attributes to figure out how a particular mutex methods should behave. Start with the no protocol variants. This eliminates the CORE_MUTEX_DISCIPLINES_FIFO and CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
* posix: Delete POSIX_Mutex_Protocol::process_sharedSebastian Huber2016-05-301-2/+0
* posix: Remove dead code and shrink commentSebastian Huber2016-05-201-35/+3
* posix: Avoid Giant lock for mutexesSebastian Huber2016-04-211-6/+0
| | | | | | | Delete _POSIX_Mutex_Get(). Use _POSIX_Mutex_Get_interrupt_disable() instead. Update #2555.
* score: Rename _POSIX_Absolute_timeout_to_ticks()Sebastian Huber2015-07-281-1/+0
| | | | | | Rename _POSIX_Absolute_timeout_to_ticks() to _TOD_Absolute_timeout_to_ticks() and move it to the score directory. Delete empty <rtems/posix/time.h>.
* score: Delete CORE_mutex_Control::lockSebastian Huber2014-03-311-6/+1
| | | | | | | | The holder field is enough to determine if a mutex is locked or not. This leads also to better error status codes in case a rtems_semaphore_release() is done for a mutex without having the ownership.
* score: PR2152: Use allocator mutex for objectsSebastian Huber2014-03-311-7/+2
| | | | | Use allocator mutex for objects allocate/free. This prevents that the thread dispatch latency depends on the workspace/heap fragmentation.
* posix: Handle recursive attributes correctly.Chris Johns2013-08-141-1/+1
| | | | | | The recursive field in the pthread_mutexattr_t is now not used. The code in pthread_mutexattr_settype only sets the type field and not the recursive field.
* posix: Create priority implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API.
* score: Avoid direct usage of _Thread_ExecutingSebastian Huber2013-07-181-0/+1
| | | | | | Pass the executing thread as a function parameter. Obtain the executing thread inside a thread dispatch critical section to avoid problems on SMP.
* score: Create mutex implementation headerSebastian Huber2013-07-181-1/+1
| | | | | | Move implementation specific parts of coremutex.h and coremutex.inl into new header file coremuteximpl.h. The coremutex.h contains now only the application visible API.
* posix: Create mutex implementation headerSebastian Huber2013-07-181-1/+1
| | | | | | Move implementation specific parts of mutex.h and mutex.inl into new header file muteximpl.h. The mutex.h contains now only the application visible API.
* score: Add and use _Objects_Put()Sebastian Huber2013-06-071-1/+1
| | | | | | Add and use _Objects_Put_without_thread_dispatch(). These two functions pair with the _Objects_Get() function. This helps to introduce object specific SMP locks to avoid lock contention.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #2Alex Ivanov2012-12-151-4/+11
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7988213
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* Update copyright.Joel Sherrill2009-07-061-1/+1
* 2009-07-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-061-22/+43
| | | | | | | * posix/Makefile.am, posix/src/mutex.c, posix/src/mutexinit.c: Add initial support for the pthread mutex type attribute added by UNIX98. It can be normal, recursive, errorcheck or default. * posix/src/mutexattrgettype.c, posix/src/mutexattrsettype.c: New files.
* 2009-06-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-291-8/+7
| | | | | | | | * posix/src/killinfo.c, posix/src/mutexinit.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/pthread.c, posix/src/pthreadexit.c, posix/src/pthreadinitthreads.c: Remove includes of <assert.h> where possible. Make other uses conditional on ifdef RTEMS_DEBUG.
* Eliminate TRUE/FALSE.Ralf Corsepius2009-02-031-1/+1
* 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed.
* 2007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-131-0/+7
| | | | | | | | | | | | | | | | | | | | | | * posix/Makefile.am, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c, posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c, posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c, posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c, posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c, posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split files into one function per file. * posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c, posix/src/aio_read.c, posix/src/aio_return.c, posix/src/aio_suspend.c, posix/src/aio_write.c, posix/src/lio_listio.c, posix/src/sched_getparam.c, posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c, posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c, posix/src/sched_setparam.c, posix/src/sched_setscheduler.c, posix/src/sched_yield.c: New files. * posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed.
* 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-031-23/+0
| | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/malloc.c, libmisc/monitor/mon-command.c, posix/preinstall.am, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c, posix/src/mutexdestroy.c, posix/src/mutexinit.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/include/rtems/sptables.h, sapi/src/exinit.c, score/include/rtems/system.h, score/include/rtems/score/mpci.h, score/src/mpci.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/wkspace.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred.
* 2007-11-30 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-11-301-5/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/semaphore.h, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c, rtems/src/timerfireafter.c, score/include/rtems/system.h, score/include/rtems/score/corebarrier.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h: Restructed to move the OBJECTS_LOCAL case to the top of the switch statement and eliminate the fall-through return of POSIX_BOTTOM_REACHED. These changes produced simplier assembly code and allowed for complete test coverage. Also applied some consistency to the functions that translate the core status codes to POSIX status codes. * posix/src/mutextranslatereturncode.c, posix/src/semaphoretranslatereturncode.c: New files. * posix/src/mutexfromcorestatus.c: Removed.
* 2007-11-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-11-281-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c, posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h: Remove all pretense of POSIX MP support. The support in place was only a shell. This should make maintenance easier. * posix/include/rtems/posix/condmp.h, posix/include/rtems/posix/mqueuemp.h, posix/include/rtems/posix/mutexmp.h, posix/include/rtems/posix/pthreadmp.h, posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c, posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* 2007-10-26 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-10-261-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c, score/include/rtems/score/object.h, score/src/corerwlocktimeout.c, score/src/mpci.c, score/src/objectgetnameasstring.c, score/src/threaddelayended.c, score/src/threadqtimeout.c: When multiprocessing is disabled, do not even allow the constant OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results in the generation of binary code which can NOT be reached.
* Remove stray white spaces.Ralf Corsepius2004-04-161-8/+8
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/rtems/posix/key.h, src/cond.c, src/condinit.c, src/intr.c, src/key.c, src/keycreate.c, src/keydelete.c, src/killinfo.c, src/mqueue.c, src/mqueuecreatesupp.c, src/mutex.c, src/mutexinit.c, src/psignal.c, src/pthread.c, src/semaphore.c, src/semaphorecreatesupp.c: Modified as part of above.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* Added support for simple binary semaphores in addition to the highJoel Sherrill2000-01-051-1/+5
| | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority.
* Split mutex.c into multiple files.Joel Sherrill1999-11-021-0/+180
