path: root/cpukit/posix/macros/rtems/posix/mqueue.inl (follow)
* 2001-05-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-171-10/+29
| | | | | * macros/rtems/posix/mqueue.inl: Implemented missing routines to support message queue FDs.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-1/+3
| | | | * macros/rtems/posix/mqueue.inl: Add cast so negation works.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-011-0/+80
* Added macro support to POSIX API. This is known to compile. * macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl: New files. * configure.in: Removed error check for enabling macros. * rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines since you cannot have prototypes for macros. * macros/rtems/posix/Makefile.am: Added files.
