* configure.ac, itron/Makefile.am, itron/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h,
include/rtems/posix/config.h, include/rtems/posix/intr.h,
include/rtems/posix/key.h, include/rtems/posix/mqueue.h,
include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h,
include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h,
include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h,
include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h,
include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl,
inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl,
inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl,
inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl,
inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl,
macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl,
macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c,
src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c,
src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c,
src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c,
src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c,
src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c,
src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c,
src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c,
src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c,
src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c,
src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c,
src/pthreadexit.c, src/pthreadgetcpuclockid.c,
src/pthreadgetcputime.c, src/pthreadgetschedparam.c,
src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c,
src/pthreadself.c, src/pthreadsetcputime.c,
src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c,
src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c,
src/sigfillset.c, src/sigismember.c, src/signal_2.c,
src/sigpending.c, src/sigprocmask.c, src/sigqueue.c,
src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c,
src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
* macros/rtems/posix/mqueue.inl: Implemented missing routines
to support message queue FDs.
* macros/rtems/posix/mqueue.inl: Add cast so negation works.
* Added macro support to POSIX API. This is known to compile.
* macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl,
macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl,
macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl,
macros/rtems/posix/timer.inl: New files.
* configure.in: Removed error check for enabling macros.
* rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines
since you cannot have prototypes for macros.
* macros/rtems/posix/Makefile.am: Added files.
