* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -1/+0 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-10 | 1 | -3/+3 |
* | 2009-11-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-11-23 | 1 | -0/+6 |
| | | | | | * mghttpd/mongoose.c: crypto_sw table is not used when SSL is disabled. RTEMS does not have flockfile/funlockfile. | ||||
* | Various 16bit fixes. | Ralf Corsepius | 2009-11-17 | 1 | -7/+7 |
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2009-11-17 | 1 | -0/+4 |
* | Add HAVE_SYS_MMAN_H HAVE_DLFCN_H. | Ralf Corsepius | 2009-11-17 | 1 | -0/+4 |
* | Convert to unix encoding. | Ralf Corsepius | 2009-11-17 | 2 | -4978/+4978 |
* | New. | Ralf Corsepius | 2009-11-17 | 3 | -0/+56 |
* | 2009-11-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-17 | 3 | -0/+5159 |
* mghttpd/mongoose.c, mghttpd/mongoose.h, mghttpd/mongoose.1: Import from svn http://mongoose.googlecode.com/svn/trunk (r477). |
