path: root/cpukit/mghttpd (follow)
* Update to Mongoose 3.9 at the last point before the MIT -> GPL license changeNick Withers2013-12-043-1403/+2572
| | | | | | | | | | | | | | | | | | | | [That is, https://github.com/cesanta/mongoose/commit/04fc209644b414d915c446bb1815b55e9fe63acc. See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI] The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied: - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below) ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support) mg_connect(), mg_url_encode() and mg_vprintf() were additionally marked "static" to silence warnings. mongoose.1 appears to have been removed from the upstream distribution. Note that the API's changed, for example: - A struct mg_callbacks must now be provided to mg_start(). Initialise members to NULL to disable various types of callbacks - Callback interfaces have changed significantly in general - The short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream) - The "max_request_size" options has been removed
* mghttpd: Requires POSIX to build server and testsJoel Sherrill2012-10-032-0/+4
| | | | | | Formerly, mghttpd was conditional only on networking being enabled. It uses on pthread and must also be conditional on POSIX threads support being enabled.
* mghttpd: Clarify commentChristian Mauderer2012-07-121-4/+4
* mghttpd: Add stack size and scheduling optionsChristian Mauderer2012-07-122-0/+66
* mghttpd: Use MD5 librarySebastian Huber2012-07-121-0/+5
* mghttpd: Use HAVE_CONFIG_HSebastian Huber2012-07-121-0/+4
* mghttpd: Update MongooseChristian Mauderer2012-07-124-4797/+4292
| | | | | | Update to Mongoose Mercurial revision 268:38a02c8a6744 available at: https://code.google.com/p/mongoose/
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-1/+0
* Whitespace removal.Ralf Corsepius2009-12-101-3/+3
* 2009-11-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-231-0/+6
| | | | | * mghttpd/mongoose.c: crypto_sw table is not used when SSL is disabled. RTEMS does not have flockfile/funlockfile.
* Various 16bit fixes.Ralf Corsepius2009-11-171-7/+7
* Add HAVE_CONFIG_H.Ralf Corsepius2009-11-171-0/+4
* Add HAVE_SYS_MMAN_H HAVE_DLFCN_H.Ralf Corsepius2009-11-171-0/+4
* Convert to unix encoding.Ralf Corsepius2009-11-172-4978/+4978
* New.Ralf Corsepius2009-11-173-0/+56
* 2009-11-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-173-0/+5159
* mghttpd/mongoose.c, mghttpd/mongoose.h, mghttpd/mongoose.1: Import from svn http://mongoose.googlecode.com/svn/trunk (r477).
