path: root/cpukit/libnetworking/rtems (follow)
* Moved sparc specific version of in_cksum_hdr to an inline routine likeJoel Sherrill1999-04-011-31/+0
| | | | | the reset of the CPU specific implementations after comment from Eric Norum.
* Patch from Eric Norum <eric@skatter.usask.ca> which changed the exitJoel Sherrill1999-03-311-2/+1
| | | | sequence.
* Removed warning for `#ifdef' argument starts with punctuation.Joel Sherrill1999-03-301-1/+1
* Patch to add shutdown() routine from Tony R. Ambardar <tonya@ece.ubc.ca>.Joel Sherrill1999-03-301-0/+25
* SPARC optimized version of IP checksum header routine. SubmittedJoel Sherrill1999-03-231-0/+32
| | | | by Jiri Gaisler <jgais@ws.estec.esa.nl>.
* Patch from Eric Norum <eric@skatter.usask.ca> to improve parsing ofJoel Sherrill1999-03-232-0/+45
| | | | | network interface names. This change does not introduce any compatibility problems.
* Patch from Eric Norum <eric@skatter.usask.ca> that adds externalJoel Sherrill1999-03-191-4/+30
| | | | fcntl support and an external fcntl handler for sockets.
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-014-23/+35
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* Patch from Eric Norum to correct bug induced by select() patch.Joel Sherrill1999-02-052-5/+11
* Modifed to reflect transition from device driver to file system.Joel Sherrill1999-02-041-41/+4
* Patch from Eric Norum <eric@skatter.usask.ca> to avoid dereferencing aJoel Sherrill1999-01-281-1/+4
| | | | NULL pointer.
* Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointerJoel Sherrill1999-01-261-1/+1
| | | | so that the libc code did not have to know about (struct socket).
* Made to compile after hacking tftp driver into beginnings of a mini-filesystem.Joel Sherrill1999-01-213-3/+188
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-102-119/+20
| | | | all conflicts.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-12-073-5/+12
| | | | | | | | | | | | | RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to set a timeout for most socket I/O operations. However, in RTEMS 4.0.0, those options do not affect connect or accept. I don't know of any way to put a timeout on those calls in RTEMS 4.0.0; can anybody point to one. Since it is frequently useful to have a timeout on accept, and sometimes useful to have a timeout on connect shorter than the BSD system default of 75 seconds, the following patch causes SO_RCVTIMEO to affect connect and accept.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-11-192-0/+2
| | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP.
* Added header files per request from Chris Johns to avoid problemsJoel Sherrill1998-10-121-0/+4
| | | | in include file order.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-291-3/+2
| | | | | | | | | | | | | | Remember the test to see if a socket could be read and written at the same time by two different tasks? I discovered that if both tasks attempt to close the socket a panic can occur from inside the BSD code. Closing the same socket twice from two different threads is certainly an error, but a panic is not the greatest error reporting method :-) The following small change to the socket close routine should reduce the chances of the panic.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-211-29/+101
| | | | | | | Here's a patch to make the rtems_showroute routine a little more useful. For `host' route table entries the link-level address is now displayed. This is equivalent to the old `show arp table' information displayed by the KA9Q code.
* Patch from Eric Norum <eric@skatter.usask.ca> to fix a cryptic errorJoel Sherrill1998-09-101-1/+3
| | | | message after comments from Eric Valette <valette@crf.canon.fr>.
* Fixed spacing. More comments from Eric Norum need to be addressed.Joel Sherrill1998-08-311-7/+7
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>:Joel Sherrill1998-08-311-0/+9
| | | | | I have reworked the ethernet driver for the BSP pc386 and here is the patch to apply.
* All warnings removed.Joel Sherrill1998-08-213-1/+20
* Patches from Eric NorumJoel Sherrill1998-08-201-3/+17
* Added CVS IdsJoel Sherrill1998-08-2014-0/+51
* Fixed many warnings.Joel Sherrill1998-08-202-1/+2
* Base filesJoel Sherrill1998-08-1915-0/+2630
