* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | 2012-03-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsépius | 2012-03-02 | 1 | -182/+188 |
| | | | | | * libnetworking/resolv.h: Partial sync with FreeBSD. Add decls for res_send_setqhook, res_send_setrhook. | ||||
* | Make self-contained. | Ralf Corsepius | 2011-05-12 | 1 | -0/+1 |
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 1 | -1/+1 |
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | 2007-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-11 | 1 | -60/+60 |
| | | | | * libnetworking/resolv.h: Typo fixes. Remove __P(). | ||||
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+306 |
