path: root/cpukit/libmisc/shell/main_wkspaceinfo.c (follow)
* basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber2015-10-261-2/+2
* score: Return heap stats via _Heap_Get_informationSebastian Huber2014-11-281-1/+2
| | | | Print out heap statistics via the MALLOC and WKSPACE shell commands.
* PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__Sebastian Huber2013-08-081-1/+0
* rtems: Create message queue implementation headerSebastian Huber2013-07-221-0/+1
| | | | | | Move implementation specific parts of message.h and message.inl into new header file messageimpl.h. The message.h contains now only the application visible API.
* * libmisc/shell/main_help.c: Make rtems_shell_help_cmd,Ralf Corsepius2011-12-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | rtems_shell_help static. * libmisc/shell/main_hexdump.c: Make main_hexdump static. * libmisc/shell/main_id.c: Make rtems_shell_main_id static. * libmisc/shell/main_ifconfig.c: Make rtems_shell_main_ifconfig static. * libmisc/shell/main_ln.c: Make rtems_shell_main_ln static. * libmisc/shell/main_logoff.c: Make rtems_shell_main_logoff static. * libmisc/shell/main_ls.c: Make rtems_shell_main_ls static. * libmisc/shell/main_mallocinfo.c: Include <rtems/libcsupport.h>. Remove private decls of malloc_info, rtems_shell_print_unified_work_area_message. Make rtems_shell_main_malloc_info static. * libmisc/shell/main_medit.c: Remove private decl of rtems_shell_main_mdump. Make rtems_shell_main_medit static. * libmisc/shell/main_mfill.c: Make rtems_shell_main_mfill static. * libmisc/shell/main_mkdir.c: Make rtems_shell_main_mkdir static. * libmisc/shell/main_mknod.c: Make rtems_shell_main_mknod static. * libmisc/shell/main_mmove.c: Remove private decl of rtems_shell_main_mdump. Make rtems_shell_main_mmove static. * libmisc/shell/main_mount.c: Make rtems_shell_main_mount static. * libmisc/shell/main_msdosfmt.c: Make rtems_shell_main_msdos_format static. * libmisc/shell/main_mv.c: Include "internal.h". Make rtems_shell_mv_exit, rtems_shell_main_mv static. Remove private decls of strmode rtems_shell_main_cp, rtems_shell_main_rm. * libmisc/shell/main_mwdump.c: Make rtems_shell_main_mwdump static. * libmisc/shell/main_netstats.c: Make rtems_shell_main_netstats static. * libmisc/shell/main_perioduse.c: Make rtems_shell_main_perioduse static. * libmisc/shell/main_pwd.c: Make rtems_shell_main_pwd static. * libmisc/shell/main_rm.c: Include "internal.h". Make rtems_shell_rm_exit static. Remove private decl of strmode. * libmisc/shell/main_rmdir.c: Make rtems_shell_main_rmdir static. libmisc/shell/main_route.c: Make rtems_shell_main_route static. * libmisc/shell/main_setenv.c: Make rtems_shell_main_setenv static. * libmisc/shell/main_sleep.c: Make rtems_shell_main_sleep static. * libmisc/shell/main_stackuse.c: Make rtems_shell_main_stackuse static. * libmisc/shell/main_time.c: Make rtems_shell_main_time static. * libmisc/shell/main_tty.c: Make rtems_shell_main_tty static. * libmisc/shell/main_umask.c: Make rtems_shell_main_umask static. * libmisc/shell/main_unmount.c: Make rtems_shell_main_unmount static. * libmisc/shell/main_unsetenv.c: Make rtems_shell_main_unsetenv static. * libmisc/shell/main_whoami.c: Make rtems_shell_main_whoami static. * libmisc/shell/main_wkspaceinfo.c: Make rtems_shell_main_wkspace_info static.
* 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-11-101-3/+1
| | | | | | | | | | | | | PR 1924/cpukit * sapi/include/rtems/config.h: New fields stack_space_size, unified_work_area, and stack_allocator_avoids_work_space in rtems_configuration_table. * sapi/include/confdefs.h: Removed rtems_unified_work_area (this is now part of the Configuration). Separate work space and stack space estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE configuration option. * libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c, libcsupport/src/malloc_initialize.c: Update due to API changes.
* Add __attribute__((unused)) to unused function args.Ralf Corsepius2009-01-021-3/+2
* 2008-09-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-191-0/+11
| | | | | | * libmisc/shell/main_mallocinfo.c, libmisc/shell/main_wkspaceinfo.c: Include information on whether C Program Heap and RTEMS Workspace are separate.
* Remove classinfo_tester.Ralf Corsepius2008-07-311-1/+0
* 2008-03-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-03-051-1/+1
| | | | | | | | | | | | | | | * libmisc/Makefile.am, libmisc/shell/main_cp.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c, libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c, libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial capability to automatically execute a script from the filesystem. Add echo command from NetBSD and sleep command. * libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c, libmisc/shell/shell_script.c: New files.
* 2008-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-191-3/+3
| | | | | | | | | * libmisc/Makefile.am, libmisc/shell/main_wkspaceinfo.c, libmisc/shell/shell.c, libmisc/shell/shellconfig.h: Add route and ifconfig commands. The code for these was previously in the networking guide. Disable NFS filesystem mount until that code is in cpukit. * libmisc/shell/main_ifconfig.c, libmisc/shell/main_route.c: New files.
* Revert accidental commit of test code.Jennifer Averett2008-01-071-2/+0
* 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-071-0/+52
* libmisc/Makefile.am: Add new files. * libmisc/shell/internal.h: Prototype for rtems_shell_print_heap_info() * libmisc/shell/main_mallocinfo.c: Use rtems_shell_print_heap_info(). * libmisc/shell/shellconfig.h: Add wkspace command. * libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c: New files.
